scottishjohn Posted December 11, 2018 Posted December 11, 2018 shoot me down if you like but why are you putting first joist so close to end wall. spacing is 400mm I read . so why not use some of you old wall plate,as i believe you replaced the old ones cos they were too short for those hangers to add to end walls so floor can sit on them --then move first joist away from end wall bit more --then do your 400 centres plenty of space to swing a hammer then
joe90 Posted December 11, 2018 Posted December 11, 2018 6 minutes ago, scottishjohn said: shoot me down if you like but why are you putting first joist so close to end wall. spacing is 400mm I read . so why not use some of you old wall plate,as i believe you replaced the old ones cos they were too short for those hangers to add to end walls so floor can sit on them --then move first joist away from end wall bit more --then do your 400 centres plenty of space to swing a hammer then That’s a solution I have never heard of before and it makes sense! But it will have to be the same depth as the joists to carry the ceiling below. (Nail a bit on! ).
ToughButterCup Posted December 14, 2018 Author Posted December 14, 2018 On 11/12/2018 at 21:03, scottishjohn said: [...] why are you putting first joist so close to end wall. [...] Because thats what the guidance for POSIs says the gap should be.
