Gary G Posted October 18, 2018 Posted October 18, 2018 Hi all, having trouble getting a system and contractor for ground floor render and wanted to fully clad (see planning drawing). I emailed the planner and he advised a Variation Of Condition application but thinks it’s not in keeping. I want to get the house water tight ASAP, wondered if too risky to fully clad and then put in the application and hope? Currently; Regs_Gray_B_L02_(Elevations).pdf
lizzie Posted October 18, 2018 Posted October 18, 2018 I can see you have a specific render on that drawing............seems just a standard self coloured k rend type.... monocouche I would have though you could us a different render as long as similar colour no one would notice. We used an Alumasc system, it is a vented facade system - a silcone render onto a carrier board and is for TF buildings. Installers are plentiful. Others on here have used the same system. Its not cheap but has BBA certs and guarantee. Between us here I am sure we can dredge up names in your area or Alumasc themselves have a list. TBH if you are thinking of dropping the render then I would talk to planners first, there is quite a bit of it and no render at all would change the external appearance considerably.
Mr Punter Posted October 18, 2018 Posted October 18, 2018 A BBA approved render carrier board (such as Bluclad) fixed to vertical timber battens. You do not need an approved installer. You can then choose the render and colour at your leisure.
