Composite Decking Materials
vk2003
On 12/05/2021 at 09:27, Mandana said:
Has anyone installed either product? Any problems? Happy with your choice?
This is our forever home so it’s got to last. Don’t want to be redoing in 10/15/20 years time. Will either product last that long?
I'm currently looking at this again and I think Millboard is the one I'm going for. Waiting for some more samples to arrive to make a final decision. I've only seen a small deck with it at a local installer and it did look superior to their 'own' product which they claimed (iirc) had a warranty that was as long as Millboard's, but I doubt they'll be around in 5 years, let alone 25yrs.
Prices and transport costs seem to vary quite a bit too for MB. I'll try and find my list of prices....
I used Eva-Last Infinity I-Series, its the trade one not the product sold in Wickes, its a good strong deck board, cuts fairly easily and looks good, we got the Pewter colour, the clips are a little fiddly at first but ok once you get used to them.
What's the difference between the Wickes one? I see their widths are different as well as their commplete form, but still using the specialised fixings.
(wickes) Eva-Last Arctic Birch Composite Deckboard Apex (140mm)
Eva I_series (135mm)
Is either one 'superior'? Both offer 25yr warranties. I-series is arched so better for drainage (?) and the I-beam 'feet' should also allow better ventilation if fixing these to standard timber platform. £63 in Wickes (multi-pack) or I-series a bit cheaper at £56 (e.g. https://www.mkmbs.co.uk/product/evalast-iseries-decking-grv-2s-rustic-oak-254mm-x-135mm-48m-t012079).
Millboard is around £67 inc delivery.
Have you got any pics of your decking @Toppers?
We have our boards down for almost 3 years now (Millboard) - No cleaning or maintenance at all, and looks as good as the day it went down. No warping either.
The only issue has been where there are cut ends on show; the material has a yellowish core - Millboard provided some paint to colour these areas, but it is not as durable as the proper coating.
  • 1 month later...
Has anyone found the retailer which they believe is doing the best Millboard deal at the moment?
I would need a horrific amount to do 35m of fencing (likely using decking boards mounted vertically 900mm to get 4x plank out of one 3.6m length), also clad a double garage door, maybe box the soil pipe, actual decking out the back....
