  • 1 month later...
On 7/28/2016 at 13:38, Construction Channel said:
Tell him to stop buying the cheap diamond bits. Iv been useing the same one for probably 2 years now without a problem.
The brand has worn off it now. But it was one of the thicker walled ones with wax in the Center. (6mm)
The joiner has one of those and lent it to me when I drilled the holes for the shower screen U channel. They make good progress but as they're flat, they do wander initially, even using a guide template. So I started using a combination of the cheaper arrow bits to get each hole started with good accuracy and then used the flat bit to continue - apparently the wax filled ones don't need cooling, but I did so anyway. Took a good 15 mins per hole.
