I have a plain tile roof and am planning bin putting the supply and exhaust on the roof, it's a bungalow so I don't really have roof on the walls.
I am having troubles finding suitable roof vents suitable for 180mm ducts with a hight enough capacity.
Has anyone got any one got any product recommendations?
Edited by thomas
Who ever makes your chosen roof tiles will have a vent tile to match. Put a 150mm to 100mm reducer on and then put your extract/ intake on. Attach with tape/cable ties.
Timloc do a vent with 180mm from memory and it has reducers to take it down to 100mm in stages.
180mm is a big duct - what’s the flow ..??
Flow is around 55 l/s off the top of my head.
If I use 2 tile vents per supply and exhaust and split with a 180mm Y then reduce to 100mm do you think this will work?
Thanks @peterw you made me go check th duct size on the unit and it's 150mm, i was told the wrong size ?
That should be easier to find vents.
  • 1 month later...
Did you find a suitable vent for your roof?
I'm currently having my roof re-tiled with plain rosemary tiles and I was really struggled to find a suitable vent, in the end I went with the Ubbink UB41. They have the usual looking dome with the air that comes out underneath and provide 20k of air movment. Theres a option for plain tiles but I couldn't find one in terracotta colour. So in the end I went for the universal one, which just has a plastic skirt that can go under the tiles. Won't look as good, but should do the job.
They go up to 160mm aswell, Bit smaller than you require but I would have thought it would been fine.
Edited by AdamSee
