Ok so I’m having a block n beam floor,
so telescopic air vents,connected to an air brick
now because I’m strange and like to be a bit special I would like round vents on the outside, these do not need to be brick shaped as I won’t be having any brickwork visible
what im after are people’s thoughts on the type of flexible pipe to run in my wall void and down below the floor level
i was thinking about 100mm duct the heavy duty type for underground, not the white curly stuff you use on an extractor fan.
What do you think, utter lunacy
cheers russ.
You can get nice 68mm soffit vents that fit neatly into a standard downpipe connector so you can use cheap downpipe, couple of elbows and jobs done ....
Do you think 68mm would have enough volume and air flow to satisfy bc
i was thinking 100mm underground duct with 100mm round vents.
