ProDave Posted June 27, 2018 Share Posted June 27, 2018 I don't like the idea of a wet solum and poor ventilation means it will be very humid under there, putting any timber at risk. I would want that sorted, and a vapor barrier and some gravel to hold it down would be the easiest, pour a concrete slab would be better. Then whatever you do in terms of insulating the floor it will be in a less damp environment. Link to comment Share on other sites More sharing options...
Daniel C Posted June 27, 2018 Author Share Posted June 27, 2018 I should be able to post some photos of the crawls space next week, I am not sure if it would help in the decision or not. So right now, everyone agrees that I should install the vapour barrier on the bottom of the crawls space as well as below the UFH and screed? (sorry for keep repeating your answers, just want to make sure I understand it right) Link to comment Share on other sites More sharing options...
Thedreamer Posted June 27, 2018 Share Posted June 27, 2018 Just out of interest what height is below your joists, are you able to crawl? With my suspended timber floor I can just about lie flat. Link to comment Share on other sites More sharing options...
Daniel C Posted June 27, 2018 Author Share Posted June 27, 2018 It is about 30 cm, so not really, but I will remove all the floor joists, and put down new floor as ply wood, so I will be able to do what ever I want. Link to comment Share on other sites More sharing options...
Daniel C Posted July 2, 2018 Author Share Posted July 2, 2018 I'm currently thinking to use EPS instead of PIR for floor insulation, is this a good or a bad idea? Link to comment Share on other sites More sharing options...
Jeremy Harris Posted July 2, 2018 Share Posted July 2, 2018 8 minutes ago, Daniel C said: I'm currently thinking to use EPS instead of PIR for floor insulation, is this a good or a bad idea? It's fine, but EPS needs to be about 50% thicker to get the same insulation value. Sometimes you can get EPS at a better price overall, and if you have the space to fit the extra depth, then EPS is fine. Link to comment Share on other sites More sharing options...
Daniel C Posted July 3, 2018 Author Share Posted July 3, 2018 So I should use 225mm if I want to go for 150mm, that might be an issue... I was even just looking at how poisonous/harmful the materials are and they said EPS is better. At the end it will come down on space and price I guess This is how the crawlspace looks like, sorry for the bad photos not really sure which angle would be the best for the crawls space, but it might give a bit of an insight: Link to comment Share on other sites More sharing options...
