A friend of mine has just finished a build and covered it in mid range Spanish slate roof tiles.
It is noticeable that a number of the slates are no longer laying flat on the slate below at the
leading edge. That they have curled up a bit like the pages of a book as they have dried out?
It may obviously be an issue under driving rain, but how common is this as I've never seen it
before and I am planning a slate roof on our project?
I have never heard of slates curling from drying out. We’re they definitely flat when they were laid?
You would normally get a kicker from nailing them on too hard or the previous slate having a thick top,
worst case is the slate has actually snapped so you would need to pull it out with a slate rip then relay a new one on a lead or copper tingle.
( assuming this is standard slating not nulock or fake slates)
More likely the battens or rafters have shrunk or twisted or a fixing or slate is broken.
When you buy your slate, make sure that they are consistent thickness and straight grain.  Get a stack of about 12 and see if they wobble when you press the corners.
