Hi,
Plumbing 101 question! I fitted a water filter under the kitchen sink which feeds a separate tap. The new tap is still a bit loose and can swivel easily. I need to tighten the nut under the sink but it's at the back left of the sink unit.
Simple question - what's the best tool to use? Should I buy a basin wrench or try with a pliers?
Thanks!
This is the one ive got. Change the heads over for 1/2' or 3/4" tap connectors, but the head also move so it will do varying sizes too, like the back nuts. As you apply pressure it tightens its grip.
