March 19, 20188 yr I found the following technical intro to cement usage during home construction useful and thought it would help others at the bottom end of the learning curve like me. Now I know how many bricks can be laid when a full 25kg OPC bag is used. Published by Blue Circle. https://tarmac-bluecircle.co.uk/wp-content/uploads/2018/01/Builders-Guide-170118a.pdf
March 19, 20188 yr You mean how many it might be. Depends how much hits the labourers face ,hair and clothes when he is staring into the mixer. How much spills out when the barrow is full to the limit and how much the brickie drops down the cavity.
March 20, 20188 yr That's a really useful post @epsilonGreedy. Thanks very much indeed. It's so useful to have the theory as a starting point, and even more useful to have the experts cast a jaundiced eye over the guidance. The guidance does contain the following sentence ' ... These quantities do not include any allowance for wastage. ...' (Not that @Declan52 suffers from jaundice )
March 20, 20188 yr Author @recoveringacademic Thanks for tagging up my OP. Are these tags exposed to Google & Bing or do they just aid in-forum searches?
March 20, 20188 yr 1 hour ago, recoveringacademic said: Not sure. Guess.... yes. Yes they are, as the urls are public. Unless the site is configured to ban search engines by using the robots.txt file, or some other less obvious way. And you can link to all the posts on a given tag: https://forum.buildhub.org.uk/tags/cement/ But a forum has so many ways in that the amount of extra search prominence without external links may not be *that* great. F Edited March 20, 20188 yr by Ferdinand
