Tennentslager Posted June 24, 2016 Posted June 24, 2016 1964 standard 3 bed semi. SWMBO fancies a kitchen/diner. The wall between the dining area and kitchen is brick or block and 120mm thick. Runs parallel with the 1st floor joists. Above is a bathroom and bedroom but the wall between these is NOT directly above the wall I'd like to remove. It's about 400mm out. What investigations must I do? I know I'll need a building warrant and an electrician and plasterer but is this diy able??
Declan52 Posted June 24, 2016 Posted June 24, 2016 Pop a floor board above and confirm if any joists are sitting on the wall. After that it's a couple of accrows and a big sledge and fill your boots. Depends on what you find you might need a steel beam in as support.
Tennentslager Posted June 24, 2016 Author Posted June 24, 2016 I'll take a pic and report back. Like the idea of the first swing of a sledgehammer...Just got to map the heating pipes and cables first. There's many sockets on this internal wall, does this mean a new consumer unit? Thought I'd read if your doing some work like this it triggers a regs update on other electicals?
PeterW Posted June 24, 2016 Posted June 24, 2016 Parallel to the wall would indicate its not load bearing, but it could be butressing the outer wall so if you can leave a stub it would help in that instance to stabilise the outer wall. If its not structural, why would you need BC...?
Tennentslager Posted June 25, 2016 Author Posted June 25, 2016 12 hours ago, PeterW said: If its not structural, why would you need BC...? I'll take a pic and report back. Like the idea of the first swing of a sledgehammer...Just got to map the heating pipes and cables first. There's many sockets on this internal wall, does this mean a new consumer unit? Thought I'd read if your doing some work like this it triggers a regs update on other electicals?
