swisscheese Posted February 19, 2018 Posted February 19, 2018 I'm looking for a brush on sealer for internal brick work, colourless and clear. Any recommendations. Cheers 1
Ferdinand Posted February 19, 2018 Posted February 19, 2018 (edited) WHat job is it doing? Consolidation or making it shiny or waterproofing or something else? In 2013 I put a sun room against an 'orribly dusty el-cheapo as built in 1850 old brick wall for a tenant, which brought an outside wall inside. We talked about render and masonry paint and doodah-wotsit miracle coating etc. In the end I gave it a good wire-brushing and a couple of coats of PVA diluted and the T is still happy and likes the character. That is the cheap'n'cheerful solution that worked for us. Should there ever be an issue I can probably just add something else later. Any problems will be indicated by you being forced to do that bit of hoovering ! Ferdinand Edited February 19, 2018 by Ferdinand
Onoff Posted February 19, 2018 Posted February 19, 2018 Thompson's Water Seal? It won't breathe very well though... 1
swisscheese Posted February 19, 2018 Author Posted February 19, 2018 Consolidation, but non-shiny. Something to add a little durability and definition and detail would be good, if that exists.
