7 hours ago7 hr It's been minus 6 overnight here in the Scottish Borders so I am thinking ahead to next winter when I hope to be living in a static on site. I read Jenki's excellent blog post about fitting an ASHP into a static. The post is 4 years old now so I thought I would go fishing for more up to date experience as the unit he mentioned doesn't seem to be available any more unfortunately.Has anyone else has tried this and if so do they have any advice or info to offer. Cheers
7 hours ago7 hr These are the options I've seen talked about for DIY install:https://www.appliancesdirect.co.uk/ct/heating-and-air-conditioning/air-conditioners/wall-mounted/r290Haven't checked the price in a while, my have they got more expensive! Pretty sure they used to be <£500.They are R290 which has some safety risks in enclosed spaces. Read up on that before you go ahead to decide if that's a trade off your are happy with. Edited 7 hours ago7 hr by -rick-
7 hours ago7 hr Author Thanks Rick. Is R290 the only way it can be done? I'm very much at the beginning of my learning curve on this.
6 hours ago6 hr r290 is afaik the only legal route to a diy install involving running your own refrigerant lines. Any other gas requires an F-gas registered installer.There are entirely enclosed systems (including on that page) that don't require touching refrigerant. They can use other gases (r32 these days) that have less safety concerns while still being DIY.Having said that, in a camper type setup you would traditionally encounter propane gas stoves and my personal assessment is that the risks of an r290 split system are no worse (likely better) than a propane stove so long as internal unit is on an external wall and the pipework run externally. But that is an assessment you have to make for yourself.For a finished house, I'd far prefer to avoid any piped gases within the property. Keep them outside in a monobloc ASHP and plumb water from there, use an induction stove.edit: r290 is a pure form of the propane gas you would use on a propane stove. Edited 6 hours ago6 hr by -rick-
6 hours ago6 hr If the site where the caravan is to be is where youre self building a house, then can you install the houses ASHP and temporarily use that for the caravan until the house is built??
6 hours ago6 hr 1 minute ago, Dillsue said:If the site where the caravan is to be is where youre self building a house, then can you install the houses ASHP and temporarily use that for the caravan until the house is built??It's an option, assuming you aren't using MCS. Doubt you'd be able to make it work with an MCS approved install (even if under the umbrella schemes). You'd also need to provide emitters (fancoils, radiators, ufh) which you might not be able to move to the finished build and which themselves might not be that much cheaper than the split system.
6 hours ago6 hr Author 7 minutes ago, Dillsue said:If the site where the caravan is to be is where youre self building a house, then can you install the houses ASHP and temporarily use that for the caravan until the house is built??I'd assumed it would be overspecced, like having a woodstove that's too big for the space.
6 hours ago6 hr 1 minute ago, Square Feet said:I'd assumed it would be overspecced, like having a woodstove that's too big for the space.Maybe, maybe not.AFAIK you want really high spec insulation so your finished house may have somewhat similar demands to the much smaller but much less insulated caravan. Heatpump would likely still be overspecced but maybe would run in winter within it's available modulation band.
6 hours ago6 hr Our 4kW Haier can modulate down to 1kW, never seen it do it, but in theory it can. Decent spec of house and a normal caravan (static home) are likely to have a similar heat loss anyway. Maybe the caravan will leak heat faster.You may need a volumiser to get a proper water volume.
5 hours ago5 hr 1 hour ago, -rick- said:It's an option, assuming you aren't using MCS. Doubt you'd be able to make it work with an MCS approved install (even if under the umbrella schemes). You'd also need to provide emitters (fancoils, radiators, ufh) which you might not be able to move to the finished build and which themselves might not be that much cheaper than the split system.The OP seems to be in Scotland where I don't think there's any BUS for a new build and not necessarily a need for MCS/umbrella schemes.You may well be right about the emitters though but that's for the OP to work out.....when I put in our HP half the upgraded rads came off marketplace and eBay for peanuts:). Might struggle to get low temp rads into caravan mind you!
5 hours ago5 hr I've just had two similar fitted but in Med region. Supplied and fitted, €1800.Near to silent. Rooms are 35m2 ish each. Heated from 15°C to 20 in an hour.The fitting was by 2 blokes and took 90 minutes for the pair. In abroadland style they just plugged them both into one socket.My only advice? Looks doable diy. I'd only buy a recognisable brand.On a caravan I'd be inclined to fit a ply mounting for strength and avoidance of vibration.
4 hours ago4 hr 14 minutes ago, saveasteading said:My only advice? Looks doable diy. I'd only buy a recognisable brand.AFAIK electriq are the only company selling r290 units because r290 is legally/safetywise considered iffy inside a residential space. (Not aware that it's outright banned, but likely non-compliant with recommendations).BUT it is definitely illegal to install a F-gas unit (anything other than R290) if you are not F-gas registered. The government has also pushed back hard against any reseller who will sell a F-gas unit to a non-registered installer (after various companies came out with 'self install' products). AFAIK you can buy them but only if you provide details of the installer to the reseller. They won't sell to someone without an F-gas installer lined up.Edit: others on here have installed electriq units, don't remember any major issues but worth a search if considering. Edited 4 hours ago4 hr by -rick-
1 hour ago1 hr 1 hour ago, Dillsue said:The OP seems to be in ScotlandOK so I can't bring one back for you 😕.You just put it on the trolley at the local eq of b and q. Mine appear to be R30 whatever that means but perhaps the diy ones are different. Surprisingly big actually when boxed up.
Just now1 min Author 6 hours ago, JohnMo said:Our 4kW Haier can modulate down to 1kW, never seen it do it, but in theory it can. Decent spec of house and a normal caravan (static home) are likely to have a similar heat loss anyway. Maybe the caravan will leak heat faster.You may need a volumiser to get a proper water volume.I'm sure the caravan would leak air and heat like a sieve so that might work. Thanks all.
