4 hours ago4 hr the silly idea i had last night can you have 2 different meters from different suppliers?i have 3 phase so could split it If i could get another supplier to fit a meter and go for a very cheap rate tariff -even if night only say 15p or less use that to charge battery when it can -- then i would get a my good export rate through current octopus flux deal ? where i get 21p at low rate and 27.6 at high rate
3 hours ago3 hr I believe you could but any savings from a better tariff would likely be offset with the double standing charges and cost of installation.Better to spend your time optimising what you have, including load shifting.
2 hours ago2 hr Two standing charges as well, you can good export rates via Agile outgoing as well. Good imports via various tariffs, with one meter, add Axle to mix for export, which you are not allowed to do with Flux.Currently on Cosy at 14p 3x a times and todays export rates on Agile get upto about 22p, other days higherDo Predbat or similar to manage your in and out electricity and demand usage.
Just now1 min Importing on one phase then trying to export on another phase could lead to a bit of a bang.Would need to have some reliable switching of the battery between phases and youd likely need to speak to your DNO to get a second MPAN
