5 hours ago5 hr Our build is moving on nicely. We should be watertight some time in December 🤞🥳We’re reviewing our lighting strategy. Current plan is for all (or most) lighting to be DALI-2, controlled via an Atios Smartcore and Home Assistant.We have quite a few Hager Klik-7 marshalling boxes (more than enough for the whole house) and am thinking that this could be a neat way to run the lighting. We also already have the Smartcore (so I could have a play around with it before committing) and a lot of DALI kit… presence detectors, drivers & luminaires.There are plenty of convenient accessible spaces to house the boxes.So… just looking for a sense check really. Any downsides of using the Klik system? We installed a load in our factory/office some years ago (albeit not the DALI version) and without wishing to tempt fate have had zero issues. Made installation a doddle too 👍Thanks :)
5 hours ago5 hr Oh that Atios Smartcore looks good. Not seen it before.I'm not building atm so haven't been paying a huge amount of attention to new products recently but had previously ruled out DALI due to the lack of interfaces I wanted to use. That Smartcore may change my view.My main thought on the Hager Klik is cost. It's obviously a huge timesaver in the right place. If you have them anyway and can use them in your layout (without making access worse) then I don't see why not.Obviously using DALI may put off normal domestic electricians from touching the system but guess you are comfortable with that.
5 hours ago5 hr Author 5 minutes ago, -rick- said:Oh that Atios Smartcore looks good. Not seen it before.It certainly seems to be a nice bit of kit and very straightforward to use. Proof of the pudding will come in time though… I’ll add my thoughts once it’s been installed for a while :)5 minutes ago, -rick- said:I'm not building atm so haven't been paying a huge amount of attention to new products recently but had previously ruled out DALI due to the lack of interfaces I wanted to use. That Smartcore may change my view.My main thought on the Hager Klik is cost. It's obviously a huge timesaver in the right place. If you have them anyway and can use them in your layout (without making access worse) then I don't see why not.Yup… they were virtually free, so it seems daft not to consider using them, but otherwise you’re right… not particularly cheap.5 minutes ago, -rick- said:Obviously using DALI may put off normal domestic electricians from touching the system but guess you are comfortable with that.I am… might change my mind in the future though, if/when I have to pay someone else to work on it 😬
2 hours ago2 hr So I understand Dali-2 is a hardwired lighting control system. It claims reliability as a result of being hard wired. But hard wiring control to every device and having to choose Dali-2 controllable lights seems like quite a constraint.The atios smartcore seems to offer a wireless matter interface. But isn't DALI-2 a bit like using ethernet cabling when the flexibility and cost advantages of wifi are available. Technology on the way out rather than the way in ?Home automation/Smart home used to be a case of paying some specialist installer mega bucks to install systems like Dali, control4 etc And then paying them again every time you wanted them to come back and extend or reprogramme the thing. But Smart Home is breaking out of that mold into ordinary homes and user friendly apps.I don't know that you are wrong because I don't know Dali or your budget, but maybe are you sure ?
2 hours ago2 hr Frankly, I greatly dislike the move to wireless everything in smart home. It's obviously easier for retrofit or DIY installs but if you follow the heavy users of wireless devices a very common complaint is that they are flaky and when there are issues they are difficult to diagnose. Matter/Thread is supposed to make this better but there are plenty of complaints out there about that too. Hard wiring is still the most reliable way to go (and much less hackable if that's a concern).DALI is traditionally a much more installer thing but this Smartcore looks much better. DALI drivers seem one of the most easily available hard wired 'smart' lighting drivers so if you want to hard wire and have an easy diy friendly control option then it's well worth looking at.
50 minutes ago50 min 100% agree using wired connection wherever possible / reasonable.DALI is my preferred technology for lighting. I've had some domestic contractor give a massive markup (additional £100 per point!) for DALI but in reality it should if anything be simpler for them: one loop per floor, no need to route cables from switches to lights, max flexibility if things change during 1st/2nd fix.On paper DALI is great for CTT , but in practice I found it clogs the bus a lot (maybe a feature of the specific controller more than the protocol) and actually a bit of a gimmick in most residential settings IMHO. And pushes prices up more.I've never used DALI for sensors (switches nor motion). It seems overkill, heavy gauge wiring for low-power data only connection. I'd keep to KNX or Loxone Tree (on Loxone projects obv) for inputs.I'd love it if Matter came up with a half-reasonable wired alternative to (natural successor to) KNX but won't hold my breath. And it's only after >30 years on market that KNX has really started getting to a sensible price point for non-luxury builds.Hager Klik seems overkill for domestic - I just put some DIN terminal blocks with cross-connects for distro in the lighting control panel. Easily expanded and means the only cable junctions are at the light fittings themselves or in the panel.But if you have the Klik and see a sensible way to use them then why not.Will be interested in how you get on with the Atios Smartcore. I get increasing enquiries from would be customers wanting a Home-Assistant native house, and as a professional installer it's not been something I can stand behind support wise (just too many ways for it to break IME). But in time it will mature and clearly demand is increasing.(Don't get me wrong - with my technie consumer hat on I have Home Assistant everywhere !)
Just now1 min 36 minutes ago, joth said:DALI is my preferred technology for lighting. I've had some domestic contractor give a massive markup (additional £100 per point!) for DALI!! Well that would pay for the Klik PDQ if that saved that uplift36 minutes ago, joth said:On paper DALI is great for CTT , but in practice I found it clogs the bus a lot (maybe a feature of the specific controller more than the protocol) and actually a bit of a gimmick in most residential settings IMHO. And pushes prices up more.Interesting. Can you provide more colour? How many fittings on the bus? Not checked in depth about how DALI works but wonder if the controller was trying to do smooth dimming on many fittings simultaneously step by step rather than using programmed scenes on the devices and using group messages rather than individual addressing. CCT lights should just have equivalent traffic on the bus to two normal lights. RGBWW would be 5x the load.OTOH I just checked and DALI is only 1200bits/sec though so dog slow compared to modern protocols and not going to do anything fancy with that.36 minutes ago, joth said:I've never used DALI for sensors (switches nor motion). It seems overkill, heavy gauge wiring for low-power data only connection. I'd keep to KNX or Loxone Tree (on Loxone projects obv) for inputs.I'd love it if Matter came up with a half-reasonable wired alternative to (natural successor to) KNX but won't hold my breath. And it's only after >30 years on market that KNX has really started getting to a sensible price point for non-luxury builds.You can use matter over ethernet and there are some interesting physical layer ethernets out there 10base-t1s allows 8+ devices daisy chained on over a single twisted pair.36 minutes ago, joth said:Will be interested in how you get on with the Atios Smartcore. I get increasing enquiries from would be customers wanting a Home-Assistant native house, and as a professional installer it's not been something I can stand behind support wise (just too many ways for it to break IME). But in time it will mature and clearly demand is increasing.(Don't get me wrong - with my technie consumer hat on I have Home Assistant everywhere !)How do you deal with these customers? Provide them with the smart stuff connected to something basic like Apple/Google/whatever but ensure everything will work with Home Assistant if they want to switch or just send them away?
