Avoiding Shadows with Under-Cabinet LED Lighting
I’m interested in how people have positioned under-cabinet LED lighting to get even illumination across the worktop.
With LED strips, does mounting them towards the front edge of the wall units generally give the best results, or is it better to position them further back? I can imagine the placement makes quite a difference to shadows when standing at the worktop, as well as how visible the light source is from across the room.
For those who have installed this type of lighting, what positioning worked best in your kitchen? Did you use a diffuser or aluminium profile, and would you change anything if doing it again?
In a previous house I had an LED strip right behind the pelmet/cabinet rail. This was old tech and I had "dotty" LED's that went yellow in very short order and the positioning wasn't right. I replaced this with an 45-deg angle bead channel at the very back - this cast a shadow and wasn't good either
Roll forward to 2024 and lessons learnt. I (had) routed a channel right in the centre of the cabinet. This positions it a quarter of the way towards the front of a 600mm worktop. You also need to take into account the reflectivity of your splashback as this changes the light considerably. Ours is actually the same as the worktop in white so highly reflective
  • The channel has wings that cover the routed channel edges - definitely a good idea
  • Go for a high-quality as many LED's per m as you can afford as this smoothes out the light
  • I went for a CCT strip that is co-ordinated with the same (but non-winged) channel in the rooflights. This makes mood setting really easy of an evening. It works so well that I felt able to not include the hideous cost of LED cabinet lighting from the manufacturer.
Would I change anything? Hmmm - I don't think so. We had three years to plan due to planning so we had a very good idea of what we wanted and Mrs Tet was happy to delegate that part of the kitchen largely to me
I attach some pictures below
Regards
Tet
I should really take some proper pictures but that would mean a LOT of tidying up...
Agree with Tetrarch that right at the very front or right at the back are both the weak spots. Tight to the front lip you get glare when you're sitting across the room, and right at the back you just light the splashback and leave the front of the worktop in your own shadow. Somewhere around 50 to 150mm back from the front edge of the wall unit, ideally with the light angled slightly towards the wall, usually gives the most even spread.
A few things that make a bigger difference than people expect:
Use an aluminium profile with an opal diffuser. Without one you get rows of dots reflected in gloss or quartz worktops, and the profile also helps with heat so the strip lasts longer.
If the units have a light pelmet, sit the profile just behind it so the strip itself can't be seen from the table or sofa.
Go for a high density or COB strip, around 3000K to 4000K, with a CRI of 90 or more so food and worktops look natural.
Plan the driver position and cable routes before the wall units go up. Getting a feed to each run afterwards is the fiddly bit, and a driver in an accessible cupboard makes it easy to swap later.
Regards
Tet
The photos help show how the lighting has been integrated into the kitchen. The routed channel looks like a tidy solution, and matching the colour temperature with the rooflights is a nice touch for keeping the lighting consistent. Interesting to hear how your earlier installations helped you work out what placement works best.
The advice about planning the driver and cable routes before fitting the cabinets is a good point, as that could easily be overlooked until it’s too late. The opal diffuser also seems worthwhile for keeping the light looking smooth on reflective worktops. Getting the position right from the start sounds much easier than trying to correct shadows afterwards.
Agree with everything JPM said.
My downstairs floorplan is that I have a small loft above my utility so I have 5 drivers in there. One for the units, one for each of the three rooflights and one for the DS bathroom. LED all the same brand with the same drivers (and another in the US bathroom)
This did actually cause problems when installing as I had to remember to power down the bathroom circuits to stop the synching behaviour for the common control switch
Regards
Tet
Good comments.
Unfortunately you are likely to get some shadow lines or partial shadow lines from the ceiling downlights though. Their light beam gets cut off by the wall cabinets at an angle according to their distance across the ceiling. Difficult to match lumens and colour temp exactly between ceiling downlights and under wall cupboard lights.
If you are having a hob extractor (e.g. integrated) then one challenge is to find one with lights to match what you put under the wall cabinets, and to integrate control with the undercabinet lights. IMO manufacturers should be building in smart home protocol control of apppliance lighting.
When using LED puck lights brightness still seems to be a limitation - watch out for the lumen output figures - amazing how some don't even state it - honestly how can you sell a light without stating its light output - but some do.
On my latest I'm probably going to solve that by running the lights at the back of the cabinets, including behind the integrated hob (which will be pushed forward by the width of the channel to allow that).
On the wider question of where to put the lights, the safe option is towards the front of the cabinet, but mid-way is a very good alternative. However I have also run them at the back without problem. In part it depends where the under-cabinet lights are on the spectrum between pure task lighting -vs- pure decorative lighting, but also on how reflective the worktop and the splash back are, plus how visible the strips / lights will be from any seating position - for example it's easy to fully conceal them behind a pelmet at the front, but harder at the back.
As @JpManning mentioned, choosing lights with a high colour rendering index is a really good idea. Also, make sure that all lights that are likely to be turned on at the same are the same colour temperature - 4,000K is my preference (not only for the kitchen).
