Will K Posted October 6 Posted October 6 Hi Folks, Looking to better understand the role of the vcl in a warm pitched roof please, and keen to hear what the general consensus is. If there is post that covers it, apologies and pls do link in/ elaborate. About to start our first (and possibly only) self build. Planning an insulated slab, icf walls and a truss roof with osb/ ply over rafters with 2 staggered layers of PIR, then battens, membrane, tile battens and then tiles. Conscious people typically spec a VCL between the osb and the pir. Question is twofold- is this actually doing anything assuming I have properly taped the outside of the osb / junctions with wall plate (and assuming the osb is airtight (?)and given its on warm side too so dew point issues are mitigated ?). And secondly, if needed, is there a more foolproof way of doing it than laying a vcl given i will be driving long hex screws through pir into osb (ie is there any value in a liquid/ paint applied vcl or perhaps a peal and stick)? And finally, is there anything you'd do differently. Not keen on hybrid roofs with insulation between rafters and trying to make as simple for me as possible to make airtight given sealing from inside with truss connections will likely be a nightmare. Thoughts appreciated, Thanks Will
Gus Potter Posted October 6 Posted October 6 Hiya Will. Welcome to BH! Your starting point here is to really understand how a flat warm roof works. Research this and it will give you a good basic understanding of the principles. It's essential that you have a impermeable VCL between the OSB and the underside of the insulation. Have a look at Alutrix type membranes. Once you get your head a round how a flat warm roof works that then pitch it up, as you now understand the basic principles. Key things that will change are that as you pitch the roof up to say 5- 35 degrees is that everything that is above the trusses will want to roll down the roof, like slip off. The fixings and roof make up need to be designed for this, what we call roughly rolling shear, to stop everything slipping off the roof! The fixings need to be carefully designed as the rolling effect causes them to bend not least. It can be done but you have to learn a bit more first. Much also depends on your actual roof covering, each type of covering needs a different set up. Give hybrid roofs a miss until you have learnt more. You're best bet is to post a sketch of what you think you may like to do.
Stu789 Posted October 7 Posted October 7 We are doing the same thing, specified by our architectural technician - as @Gus Potter says above special fixings through the PIR and VB+underlay (Proctor products). Below is an excerpt of one of the drawings that may be useful. 1
JpManning Posted October 7 Posted October 7 It's worth being clear what the VCL is actually doing in this build up, because it answers both of your questions. With a breathable membrane above the PIR, any moist air or vapour that gets past the deck and into the insulation joints can reach the cold side and condense on the underside of the membrane or on the battens. The foil facings on the PIR are very vapour tight in themselves, but the board joints, the screw holes and the edges aren't. So the VCL isn't really about the dew point in the OSB, it's about stopping vapour getting into the insulation layer at all. Taped OSB will give you a decent airtight layer, but I wouldn't rely on it as your vapour control. Its vapour resistance varies between boards and with moisture content, so it's not something you can design to with confidence. A separate membrane laid over the taped deck is cheap insurance. The screws aren't the weak point you might expect. They go through under compression from the counter battens, and a self adhesive membrane tends to seal round the shank reasonably well. The places that need real care are the laps, the junction between the roof and your wall airtightness line at the wall plate, and anywhere services or roof windows go through. Get those detailed on the drawings before you start, as they're much harder to put right once the PIR is down. A liquid applied membrane over the whole deck would work, but it's slow and costly on a roof that size. Where liquid or paste products earn their keep is round awkward penetrations and at the wall to roof junction. As mentioned above, get the fixing design for your exact build up from the screw manufacturer, as long fixings through two staggered layers of PIR on a pitch need to be calculated, not guessed. 1
ADLIan Posted October 7 Posted October 7 +1 to above from JPM. Generally a VCL is not required with this form of construction, perhaps with the exception of high humidity buildings such as swimming pools. Check MIs and relevant BBA cert for your chosen insulation and breather type roofing membrane. Adding a VCL will make the roof safer from condensation risk.
Will K Posted Wednesday at 15:29 Author Posted Wednesday at 15:29 @Gus Potter @ADLIan @JpManning @Stu789 Many thanks guys for the swift responses and warm welcome, much appreciated. Feels like general consensus is one's needed but with varying degrees of how critical it is by sounds. I reviewed some of the warm flat roof material and it makes sense to me especially when you have an impermeable layer of epdm above, I suppose the concern if I'm understanding correctly is that the pir could cause that issue albeit it the breather/waterproof membrane above pir would potentially let some of it out... I checked out the alutrix 600 and note it needs a fluid applied primer for it. Is there anything that doesn't require going over the whole roof with primer or is this just a necc evil? With regards to stopping the slippage...is there methods that you recommend? Id heard about creating a solid fascia type upstand which would essentially act as a stop for the pir boards. And screws being driven in at the correct angle....anything else worth thinking about? Thoughts appreciated Will
JpManning Posted Thursday at 07:18 Posted Thursday at 07:18 Hi Will, happy to help. On the primer, it depends on the membrane. Some self adhesive VCLs need primer over the whole deck to get a reliable bond, while others are made to go straight onto clean, dry OSB and only want primer at laps, edges or in cold weather. The other route is a loose laid or mechanically fixed VCL with taped laps, sealed to the wall airtightness line at the plate. That's quicker and cheaper on a big roof, and because the counter battens clamp everything down it works well as long as the laps and junctions are taped properly. Check the datasheet for whichever product you pick, as primer requirements and minimum application temperatures vary a lot. On slippage, you're thinking along the right lines. A continuous timber stop at the eaves, the full depth of the insulation and fixed back through the deck into the rafters, gives the bottom row of boards something solid to bear on. After that, the counter batten fixings do most of the holding, so the fixing design matters more than anything else. Get the screw manufacturer to calculate spacing, length and angle for your pitch, insulation depth and roof loads, including snow and the weight of the tiles or slates. Some systems use screws angled up the slope, others use crossed pairs. Stagger the joints between the two PIR layers and keep the boards tight, so the load is shared and there are no gaps for vapour or cold bridging. And fix the counter battens as you go rather than laying a big area of loose boards, especially on a steep pitch or if it's breezy. A timber stop at the verges and ridge is worth having too, so the edges are closed off and there's something solid to fix the trims to. 1
Will K Posted Friday at 08:36 Author Posted Friday at 08:36 Many thanks @JpManning this is really useful, much appreciated.
JpManning Posted Saturday at 08:21 Posted Saturday at 08:21 You're welcome Will, glad it helped. One thing worth adding: when the VCL goes down, tape every lap and run it well past the wall plate so it can be sealed properly to your wall air tightness line. Do the same around anything that comes through the deck, like soil vent pipes or roof window frames. A few minutes with tape there saves a lot of grief later. Good luck with the build.
Gus Potter Posted 16 hours ago Posted 16 hours ago On 08/10/2026 at 08:18, JpManning said: Some systems use screws angled up the slope, others use crossed pairs. This is very clever and elegant by @JpManning. To do this you need to maintain absolute strict control over the workmanship. A highly competent Contractor who understands the principles is the basic minimum. It's generally not suited to self build. You have to work closely with the fixing supplier.
Will K Posted 13 hours ago Author Posted 13 hours ago Evening Folks, Still trying to get my head round an easy (as easy as possible) detail that connects icf external 150mm insulation to the 150mm PIR that i want to lay over the osb+vcl deck. Feel free to, (as brutally as you wish) dissect my scribbles. I'm assuming I'll leave an outer skin of ICF coming sightly higher and cut down trusses so I'm not having to go through rafter ends and insulate/ air tight. The idea of a block of wood on end of insulation to hold it on looks quite troublesome as does the vcl lapping @JpManning. Is there an easier/slicker way of doing this, I have contemplated using SIPS, as this would simplify this significantly but quotes have been horrendous. Cheers Will
Will K Posted 13 hours ago Author Posted 13 hours ago Oh I should probably add, the turquoise is the insulation, blue the trusses, red not needed items and the yellow a vcl
JpManning Posted 4 hours ago Posted 4 hours ago Hi Will, one way that often simplifies it is to stop the ICF a course short so the wall insulation and the roof insulation meet over the wall head, rather than trying to wrap one around the other. Run the VCL down over the wall plate and tape it straight onto the inner face of the ICF concrete or its airtightness layer, then the PIR on the deck runs out and butts tight to the outer ICF insulation, with any gap filled with low expansion foam. The eaves stop can then be a simple ply or timber upstand fixed through to the plate, kept within the insulation depth. Worth running the final detail past your SE and the ICF supplier, as they'll have standard eaves details.
