Hi,
Rather than having an inset stove we’re going to build the chimney breast out. We currently have a concrete flue that I’m hoping to knock through to and install a flexible flue liner within. Which I can then bring out into the room.
Is it possible to attach the flexible flue liner directly onto the register plate as shown in this image I came across. Can’t see any regs regarding this.
Thanks
That’s an awful lot of effort, have you considered an exposed twin wall flue? I chose this over a chimney as I prefer the simplicity and preserve the room volume. Also much better airflow around the stove.
Yes you can.  I would thoroughly recommend you get help from a local installer.  We did, we are lucky enough to have a really great guy who went through our design in detail in return for us buying all the bits from him.  I probably could have got the bits cheaper on t’internet but the difference was a small price to pay.
Not sure you want to attach the liner directly to the register plate mind…
Sorry maybe didn’t make myself clear enough, I already have a chimney with a concrete flue liner already installed. So it would just be a case of knocking through to it and then inserting a flue liner, which I could then bring out into the living room
Couldn’t you join a twin wall flue to your chimney? Might not need a flue liner or chimney breast? Would need the advice of a HETA installer of course
