September 10Sep 10 I’ve got a lot of steel to paint another layer of bitumen onto. I’m not fussed about being neat and tidy. Has anyone used a paint sprayer with particularly thick paint like this?: https://www.wickes.co.uk/IKOpro-Black-Bitumen-Paint---22-5L/p/282332
September 10Sep 10 I’ve seen other bitumen paint says it can be sprayed. Also, Glatthaar’s waterproofing layer on its basements uses sprayed bitumen, I believe.
September 10Sep 10 if you have a compressor buy a schultz gun and stick a hose onto the suction tube and dip it in your big tin. Put you tin of bitumen into a big bucket of hot water to heat it up and it will spray nicer. use celly thinners to clean stuff off. all the guns are the same so just buy a cheap one. the black gunk will gunk it up so it will go in the bin once done. wear some kind of dust mask and goggles/gloves/ppe Edited September 10Sep 10 by gaz_moose
September 10Sep 10 Author 1 minute ago, gaz_moose said: if you have a compressor buy a schultz gun and stick a hose onto the suction tube and dip it in your big tin. Put you tin of bitumen into a big bucket of hot water to heat it up and it will spray nicer. use celly thinners to clean stuff off. all the guns are the same so just buy a cheap one. the black gunk will gunk it up so it will go in the bin once done. wear some kind of dust mask and goggles/gloves/ppe @gaz_moose thanks!
September 10Sep 10 Don’t use a sprayer with the tubular filters in the gun, they last 5 minutes and block up. shultz gun as mentioned above.
