I have two installed inspection chambers of 600mm diameter both of which are to be reduced in height following a landscaping design change. As part of that change we're also looking to reduce the drain cover size to 320 or 350mm still allowing access for any required clearing.
I can find plenty of access restriction or shaft reducing caps, but none of these look like they are designed to allow a change from one riser diameter to another e.g 600mm to 320/350mm (hope the next diagram explains it a bit more)
___|    |___
Anyone know of a suitable "riser diameter changer" product?
___|    |___
Price is horrific, but shop around.
https://www.drainagesuperstore.co.uk/product/axedo-600mm-to-350mm-inspection-chamber-restrictor-ring.html?clickref=1100lDp3y34Q&reqid=73079187&affid=1694&app_clickref=1100lDp3y34Q
1 hour ago, BotusBuild said:
There must be, as it would need to take a modular access cover.
Ring them on Tuesday and ask for a solution.
14 hours ago, BotusBuild said:
it seems there is no ability to then add 320mm or 350mm riser on top of it.
Why not use a 600mm riser before it?
Talk to someone. That's a radical solution. Hope I'm not met by a bot!! 😉
24 minutes ago, BotusBuild said:
Mike, the 600mm Risers are already there 😀 Thats what I want to reduce from
You appear to want to do the left illustration below. I'm suggesting the one on the right. But maybe you're trying to do something else.
