Johnnyt Posted 17 hours ago Posted 17 hours ago I have a detached garage with its own CU and ring main. The ring recently tripped unknown to me and the inevitable happened to the contents of the second freezer. is it possible to set up an alert system to notify my phone or other of a trip, without home assistant etc or temp sensors. i have good WiFi in the garage which does not rely on the same ring. Ideas gratefully received. The ring is fine and it looks like a one-off incident with the compressor duty cycling.
-rick- Posted 17 hours ago Posted 17 hours ago Not a recommendation but there are lots of fridge/freezer monitors out there. Better to monitor the temperature in the unit vs the power supply. Here is one: https://www.amazon.co.uk/GoveeLife-Digital-Thermometer-Control-Wireless/dp/B0F9KWHV4S
Nickfromwales Posted 4 hours ago Posted 4 hours ago 13 hours ago, Johnnyt said: I have a detached garage with its own CU and ring main. The ring recently tripped unknown to me and the inevitable happened to the contents of the second freezer. is it possible to set up an alert system to notify my phone or other of a trip, without home assistant etc or temp sensors. i have good WiFi in the garage which does not rely on the same ring. Ideas gratefully received. The ring is fine and it looks like a one-off incident with the compressor duty cycling. Was it an MCB that tripped, or an earth fault device such as an RCD or RCBO? May be a good idea to take an MCB to a single socket and have the freezer running off that, to avoid future nuisance tripping. PS, if it’s tripped once, it’s likely that it’s a slow developing fault condition and it may be on borrowed time. With a freezer for bulk food stuff, I’d seriously consider a new freezer, if this one’s into double digits of old age. 1
Mattg4321 Posted 1 hour ago Posted 1 hour ago 2 hours ago, Nickfromwales said: Was it an MCB that tripped, or an earth fault device such as an RCD or RCBO? May be a good idea to take an MCB to a single socket and have the freezer running off that, to avoid future nuisance tripping. PS, if it’s tripped once, it’s likely that it’s a slow developing fault condition and it may be on borrowed time. With a freezer for bulk food stuff, I’d seriously consider a new freezer, if this one’s into double digits of old age. You can’t omit RCD protection for a specific appliance any more. In fact it’s very difficult to omit for any reason these days where BS1363 sockets are concerned 1
Nickfromwales Posted 50 minutes ago Posted 50 minutes ago 39 minutes ago, Mattg4321 said: You can’t omit RCD protection for a specific appliance any more. In fact it’s very difficult to omit for any reason these days where BS1363 sockets are concerned On existing installs, or on new? Or both?
Johnnyt Posted 15 minutes ago Author Posted 15 minutes ago It's new build 2021 and with rcbo's There is both a fridge and freezer on the ring, fortunately the fridge only had bottled beer in so no damage there. I have a few spare ways on the CU so could have a dedicated radial to it. I have ordered a wifi based thermometer alarm. Let's wait and see
