Hi everyone,
looking for some advice before I start and possibly make any major mistakes.
I'm going to be taking up an old click flooring in the hallway and laying some lvt.
Where I bought the lvt from said they would come and do a moisture test but after numerous text back and forth never turned up.
I have taped a square of polythene down but not sure if this is giving me the most accurate reading.
i can’t see or really tell if damp is present although a corner of the plaster bead is slightly rusted on one wall.
So getting to the point should I just epoxy resin prior to self level compound?
these are the materials I’ve got in my cart.
Also can you recommend the best adhesive  to use.
Regards. James
there is another thread on moisture content in new floor
 bottom line is if you want a super job -first you need to make sure its totally flat
 if any doubt hire a grinder and flatten it
then you need to use a moisture gauge
if its an old floor there should no moisture in it
if there is you have to start thinking about  rising damp through it
only then do start asking about adhesives
 when i had my new floor laid  they wanted it down to 3.5%   -- If i wanted not to wait and do it at 4,55% then the adhesive was twice the price
 even if you go for self levelling -- it is unlikley to be flat enough to just lay directly without grinding  for a perfect job
and again you need to do the moisture checks -- it will not be a moisture proof barrier
theres a perfect floor all made from little bits
@scottishjohn
thanks for your reply, I have read a few bit on here not sure if I’ve read this yet but will have another look through the forum.
the floor in question is an old existing slab which has been covered with click flooring for over 20 years.
I was hoping to just apply about 6-7mm of self level compound to raise it up and that would be ok to apply glue and lvt, I don’t think the existing floor is to bad.
this is a pic of it and you might be able to make out the rust on angle bead too.
