August 10Aug 10 17 minutes ago, Tony K said: vertically so that water can escape There shouldn't be any water.
August 10Aug 10 Author 8 minutes ago, saveasteading said: There shouldn't be any water. Now that, is a good point!
August 10Aug 10 this looks like a problem how ever you do it you have no gutters or way for water to get off the roof I personally do not like membrane roofs after seeing how crows brought things up to a roof then pecked at them and made holes in the membrane I if it were me I would start again with GRP you can buy all sorts of shaped edging, drips rail etc for use in GRP roofing systems which will allow you to want ever you want and direct the water from roof where ever you want it go like maybe fitting a gutter to a soakaway- which is fitted after you done your cladding and some lead above your brick work is only proper solution to that something that can move a little Edited August 10Aug 10 by scottishjohn
August 10Aug 10 Author 4 minutes ago, scottishjohn said: this looks like a problem how ever you do it you have no gutters or way for water to get off the roof I personally do not like membrane roofs after seeing how crows brought things up to a roof then pecked at them and made holes in the membrane I if it were me I would start again with GRP you can buy all sorts of shaped edging, drips rail etc for use in GRP roofing systems which will allow you to want ever you want and direct the water from roof where ever you want it go like maybe fitting a gutter to a soakaway- which is fitted after you done your cladding and some lead above your brick work is only proper solution to that Its not evident from the photos, but the roof runs to a gutter at the rear. I know what you mean about GRP vs Rubber, but for a garden building I think I'm pretty comfortable with rubber. I might even put a simple green roof on it to prevent crow attacks!
