john0wingnut Posted Thursday at 11:22 Posted Thursday at 11:22 Afternoon all I have just had an inspection visit for my timber frame rear extension. It is a single storey 6x2 timber frame, 400 centres, 11mm OSB on the outside, breather membrane and is to be finished with vertical thermo pine, on batten / counter batten. The BCO has advised I need to put intumescent cavity closers in at the top / bottom and around the windows and doors, which is not something I thought was required for ventilated cladding; I've just got mesh top and bottom. Windows / doors have a cladding cheek to finish, so are closed already. Can anyone on here enlighten me? John
Alan Ambrose Posted Thursday at 16:54 Posted Thursday at 16:54 The intumescent strips seem to be accepted practice. Alternatives are 0.5mm steel / wood of a given thickness (I forget how much). There’s a fair amount of discussion on this on ‘t ‘ub. My BC seemed to be more open-minded - I forget his exact words. We used the steel strip as it was cheaper, but it did take a while to put up.
G and J Posted Thursday at 17:02 Posted Thursday at 17:02 OK, I can’t help feeling I should know this, but how does a steel strip stop the ventilation behind the cladding act like a chimney during a fire whilst still allowing the chimney effect to dry the cladding under normal conditions? 1
john0wingnut Posted Thursday at 21:21 Author Posted Thursday at 21:21 Hi all So having done some reading, document B refers to a cavity as a sealed entity, vs what I would call a ventilated void behind my cladding as it isn’t sealed. I understand strips would be useful preventing fire spreading from first to second storey for example, but, if my cladding or the timber frame catches fire, no intumescent strip sealing the ventilated area is going to stop it; and given the soffit is 10mm above where the cladding finishes, it won’t stop that catching fire either. My front extension is TF with brick veneer, and drawings for that clearly advise fire proof closures at the top of the cavity and around the windows / doors which makes sense.
john0wingnut Posted Friday at 08:39 Author Posted Friday at 08:39 11 hours ago, john0wingnut said: Hi all So having done some reading, document B refers to a cavity as a sealed entity, vs what I would call a ventilated void behind my cladding as it isn’t sealed. I understand strips would be useful preventing fire spreading from first to second storey for example, but, if my cladding or the timber frame catches fire, no intumescent strip sealing the ventilated area is going to stop it; and given the soffit is 10mm above where the cladding finishes, it won’t stop that catching fire either. My front extension is TF with brick veneer, and drawings for that clearly advise fire proof closures at the top of the cavity and around the windows / doors which makes sense. Cant seem to edit the above. I misread the regs. Cavity is a considered a concealed space. Not sealed!! So that statement above is incorrect.
Alan Ambrose Posted yesterday at 10:50 Posted yesterday at 10:50 Following @G and J comments, I've been researching this again. It's not completely obvious - NHBC doesn't go into a lot of detail re timber cladding & cavities, nor the building regs. They say a bit but a picture or two would have been nice. My current thinking is that 0.5mm steel is fine around windows & doors but intumescent might be required at the top of the cavity. I've not figured out the bottom yet.
G and J Posted 23 hours ago Posted 23 hours ago I can imagine steel cavity closures round penetrations. I think the key thing is to close off the chimney (behind the cladding) when there is a fire.
Owain1602 Posted 21 hours ago Posted 21 hours ago (edited) The regs say 0.8mm steel (or thicker) and 38mm wide timber (or thicker). I agree, this can be quite a confusing topic. Whatever you do, don’t try and read the STA documents seeking clarity….it will confuse you even more! The cavity barrier element of the regs doesn’t have anything to do with the fire rating of your cladding, that’s a separate topic. They want to see how you will stop a fire from using the external cavity behind the cladding as a means of bypassing the internal fire resisting elements. There are numerous arguments and nuances that can be put forward such that the guidance as read do not apply in certain sections. Obviously, a lot of this came out after Grenfell. My understanding is that the fire service couldn’t understand at the time how fire was spreading throughout the building, especially from floor to floor so quickly. They couldn’t see the fact that fire was spreading inside the cavity behind the cladding. We had two different external claddings, one for the ground and another for the first floor, both had ventilated cavities. I specified a steel drip flashing between the two (which ended up 3mm thick). The ground floor cavity ventilates at the underside of the drip, and the start of the first floor cavity is above the drip. In the event of a fire, we wouldn’t fully close off either cavity, just that fire in the ground floor cavity would come up against a 3mm steel plate. It would have to come out of the ground floor cavity at the drip, come out 100mm to get around the drip then turn back on itself to get back to the first floor cavity. That is the detail around a lot of the house. at the heads of windows we have intumescent strips, side and bottom of windows is fully closed with 38mm or bigger timber. I had agreement from the BCO that the detail and argument I put forward for the eaves to roof was okay. But as I was doing the cladding, I had to change something to better attach the gutter. Rather than go through the whole approval loop again, I just ran intumescent strips around the whole of the eaves (not at the gables). Value my time and sanity more than about £500’s worth of strips. If you can post a bit more detail, I’m sure that we can come up with more specific suggestions. Edited 21 hours ago by Owain1602
Alan Ambrose Posted 12 hours ago Posted 12 hours ago Think 0.5mm steel rather than 0.8mm. @G and J & @Owain1602 Can I ask - did you do intumescent strip at the bottom of the cladding cavity? @Owain1602 - interested on why you didn't do the gables - did it not have the same circumstances as the eaves? BTW this is what my BCO said on this subject: Fire stopping cavity barriers are not enforceable under building regulations for individual domestic dwellings. Only enforceable in buildings with separate compartment ie flats or semi’s. Although I do think the fire stopping strip is a good idea it is your choice in this circumstance. 1
Owain1602 Posted 11 hours ago Posted 11 hours ago Apologies @Alan Ambrose, you are right, it is 0.5mm steel. We don’t have anything on the bottom of the cavity. I’m not sure what situation would be helped by a closure at the bottom, since the strips need fire to activate them. Nothing was needed at the wall to roof junction at the gables since this was completely sealed with timber, as the roof is ventilated from eaves to ridge. The comment from your BCO is similar to what I was referring to by being able to argue your case for not needing them in certain scenarios.
G and J Posted 11 hours ago Posted 11 hours ago Our sides are within a meter of our boundaries and so we have to demonstrate reasonable precautions to prevent fire spreading from one property to another. Whilst they aren’t technically enforceable it would seem odd to me to be willing to spend money on things like a robot vacuum (a similar cost level) and not on something that might save a life. In my mind once a fire is bad enough to operate the strips the house is in real trouble, the key drive is to slow stuff down long enough for everyone to get out and the fire service to prevent spread between buildings. As for positioning, I’d agree that they will be less effective at ground level, but I’d also argue that one wouldn’t want a single strip atop a 6m cladding ‘chimney’.
Alan Ambrose Posted 7 hours ago Posted 7 hours ago >>> As for positioning, I’d agree that they will be less effective at ground level, but I’d also argue that one wouldn’t want a single strip atop a 6m cladding ‘chimney’. That's an interesting point. For a highish single storey like we have (our eaves are at ~3.5m) maybe it would make sense to have it, say, 2/3rds up. If it's right at the top, the fire has to get all the way up before it operates.
G and J Posted 5 hours ago Posted 5 hours ago Some will be better than none, even if it isn’t in the perfect place. Let’s hope they are never tested.
