andreas Posted yesterday at 20:03 Posted yesterday at 20:03 Excuse the drawing, no architect here ha. Blue lines are block walls of room that are sand/cement/plaster finish. At some point someone made a boxed in area (red colour) for services. The covering of the box is a bit crap, out of alignment with the block wall and damaged. I am going to strip off and put new plasterboard covering on then skim all the walls where the pink lines are. What is the best way to join the plasterboard to the existing sand/cement/plaster finish, where the green arrow points? The existing plaster on the block wall is damaged on that join but the sand/cement underneath is fine. I was thinking chip off a couple of inches of plaster, SBR the sand/cement mix, apply mesh tape over plasterboard edge / sand cement then skim whole wall?
JohnMo Posted 23 hours ago Posted 23 hours ago I would do a timber structure attached to wall and then skin with plasterboard 1
Nickfromwales Posted 22 hours ago Posted 22 hours ago 1 hour ago, andreas said: Excuse the drawing, no architect here ha. Blue lines are block walls of room that are sand/cement/plaster finish. At some point someone made a boxed in area (red colour) for services. The covering of the box is a bit crap, out of alignment with the block wall and damaged. I am going to strip off and put new plasterboard covering on then skim all the walls where the pink lines are. What is the best way to join the plasterboard to the existing sand/cement/plaster finish, where the green arrow points? The existing plaster on the block wall is damaged on that join but the sand/cement underneath is fine. I was thinking chip off a couple of inches of plaster, SBR the sand/cement mix, apply mesh tape over plasterboard edge / sand cement then skim whole wall? Do exactly as you say, but instead of sand and cement I use dry lining (dot & dab) adhesive which is far more robust and doesn't fray like S&C does. Use a load of plasterers scrim tape to bridge between masonry and new works, and wherever fixings timber back to masonry, use plenty of solvent free gripfill behind the timbers when fixing them back to the wall, which will go off rock solid. 1
andreas Posted 2 hours ago Author Posted 2 hours ago 20 hours ago, JohnMo said: I would do a timber structure attached to wall and then skin with plasterboard The timber structure already exists, just needs re-skinning as the attempt the person made at plasterboard fitting was poor to begin with and has now got damage to it as well. My concern is the join to the existing plastered wall. I can skim the whole wall with a thin skim but not board the entire wall due to coving that I'd rather not remove (I'll never get a match). I want to avoid the plaster cracking down the join after skimming if possible.
andreas Posted 2 hours ago Author Posted 2 hours ago 20 hours ago, Nickfromwales said: Do exactly as you say, but instead of sand and cement I use dry lining (dot & dab) adhesive which is far more robust and doesn't fray like S&C does. Use a load of plasterers scrim tape to bridge between masonry and new works, and wherever fixings timber back to masonry, use plenty of solvent free gripfill behind the timbers when fixing them back to the wall, which will go off rock solid. I've back-filled the timber / masonary join as it was not great, that is now rock solid as you say. Would you trim back the plaster layer a bit and SBR the sand/cement underneath before scrim tape or just go straight on old plaster? Trying to keep skim to minimum.
Nickfromwales Posted 1 hour ago Posted 1 hour ago 5 minutes ago, andreas said: I've back-filled the timber / masonary join as it was not great, that is now rock solid as you say. Would you trim back the plaster layer a bit and SBR the sand/cement underneath before scrim tape or just go straight on old plaster? Trying to keep skim to minimum. Trim back enough to get at least 40-50mm overlap of scrim tape. It's that which will prevent cracking. 1
