Mattg4321 Posted 3 hours ago Posted 3 hours ago Another chimney related question. At the moment my chimney has a brick ‘corbel’ overhang 1 course deep, with flaunching directly on top. It’s in very poor condition and some of the bricks in this course have spalled. I’m going to remove the whole top of the stack. Ideally, I’d like whatever I use to have a drip detail on the underside - obviously not possible with brick, unless you try and carefully use a grinder? What about normal wall copings such as the below? Will the flaunching bond well with the smooth finish of the coping stone though? Ive also seen rosemary roof tiles used, but again, no drip profile. Am I overthinking this?
Mattg4321 Posted 3 hours ago Author Posted 3 hours ago https://www.wickes.co.uk/Marshalls-Smooth-Cast-Grey-Coping-Stone---140-x-600-x-50mm/p/154406
dpmiller Posted 1 hour ago Posted 1 hour ago are concrete chimney tops not a thing where you are? https://www.carryduffbuildingsupplies.com/small-chimney-coping-27-x-60-686mmx1524mm.html
