Mattg4321 Posted June 17 Posted June 17 Another chimney related question. At the moment my chimney has a brick ‘corbel’ overhang 1 course deep, with flaunching directly on top. It’s in very poor condition and some of the bricks in this course have spalled. I’m going to remove the whole top of the stack. Ideally, I’d like whatever I use to have a drip detail on the underside - obviously not possible with brick, unless you try and carefully use a grinder? What about normal wall copings such as the below? Will the flaunching bond well with the smooth finish of the coping stone though? Ive also seen rosemary roof tiles used, but again, no drip profile. Am I overthinking this?
Mattg4321 Posted June 17 Author Posted June 17 https://www.wickes.co.uk/Marshalls-Smooth-Cast-Grey-Coping-Stone---140-x-600-x-50mm/p/154406
dpmiller Posted June 17 Posted June 17 are concrete chimney tops not a thing where you are? https://www.carryduffbuildingsupplies.com/small-chimney-coping-27-x-60-686mmx1524mm.html
Mattg4321 Posted June 17 Author Posted June 17 There’s a few around on period properties, but no idea where I can get one from. Google isn’t helping, which is why I thought of a wall coping. Either that or replace the corbel course with blue engineering bricks
Oz07 Posted June 17 Posted June 17 I'd of thought any stone cill supplier would knock you one up. Obviously it would cost as bespoke. I've used Serene Stone before, try them.
Mattg4321 Posted June 17 Author Posted June 17 Unfortunately I need it in the next few days so a bespoke item is out. Also it’s quite large so I’m not sure how I’d get it up there! Chimney measures 1400x 650mm ish
