Who gives you a certificate or a copy of the install id for the inverted heating system?
Hello, I am chasing up certs for Building Control in NI. One of the things is a copy of the install id for the inverted heating system.
We had our builders who have 2 family members who installed our underfloor heating and ashp. Then they had a separate guy commission the heat pump.
The builders/plumbers a;so installed our water tank/plumbing.
Who is meant to give this certificate or copy of the install id?
The builders or the commissioners and where can i get a blank copy for them to sign?
Thanks
What is an inverted heating system?
 unvented maybe?
Assume NI same as rest of UK and the unvented cylinder would require a G3 certificate to cover the unvented cylinder install.
The heat pump install would be asking the commissioning person for a commissioning certificate.
