Alwayslearning22 Posted Thursday at 08:56 Posted Thursday at 08:56 (edited) You good people are always very helpful. can you please recommend what I could do to fix this mess? it was covered up by skirting board its a harmony timber frame construction if that helps The vapour barrier is missing in this part but its in the rest of the wall Edited Thursday at 08:59 by Alwayslearning22
Super_Paulie Posted Thursday at 08:58 Posted Thursday at 08:58 (edited) Edited Thursday at 08:59 by Super_Paulie
Alwayslearning22 Posted Thursday at 09:36 Author Posted Thursday at 09:36 36 minutes ago, Super_Paulie said: Thanks for the reply thats what I was thinking to use but I would like to prevent condensation hitting the wall plate and studs. Will this prevent that from happening? I can’t understand why someone would butcher the wall like this removing vcl and insulation etc
Alwayslearning22 Posted 17 hours ago Author Posted 17 hours ago Any other ideas on how to fix this? Don’t want to make things worse
Super_Paulie Posted 16 hours ago Posted 16 hours ago Just fill it full of foam, cut it back, skirting board back on. That's what I'd be doing.
Alwayslearning22 Posted 13 hours ago Author Posted 13 hours ago 2 hours ago, Super_Paulie said: Just fill it full of foam, cut it back, skirting board back on. That's what I'd be doing. The sane mind would do that but. I’m an ocd maniac who worries about the trapped moisture in the sole plate I also have a very damp slab that’s taking ages to dry out. Thanks for the reply
