I'm in the process of doing a full re-roof to replace old bitumen leaky felt.
Would like to go with breather membrane that is air and vapour permeable. Any recommendations please.
Pitched roof will be finished off with fibre cement tiles with a dry ridge system and eaves ventilation.
It appears most of the membranes on the market are air tight and vapour permeable and a limited supply are both air and vapour permeable.
We used this
 Permavent APEX is a 3 layer breather membrane. APEX is both air and vapour permeable
On 17/05/2026 at 08:43, G and J said:
We used this
Thank you everyone.
Had a look at the prices and SD values
Permavent £160 SD value 0.01
Roofshield £150 SD Value 0.013
and Klober £259 SD value 0.009
On paper Kolbre wins in terms of breathability but is there a bif difference between 0.009 and 0.1 SD value?
If not then I think either Permavent or Roofshield
Also I don't quite understand do these membranes to be taped or can they be used untaped.
Look at the brochure if taped for example Permavent require 100mm overlap and if untaped then 150 mm overlap.
In terms of tape- any specific type of tape ? or standard waterproof duck tape?
4 hours ago, ab12 said:
Also I dont quite understand do thes emembranes to be taped or can they be used untaped.
We did not tape but used the 150mm overlap (permavent)
Neither did we
8 hours ago, ab12 said:
So just to recap, no taping for cold roof but better to tape for warm roof?
Just follow manufacturers instructions of chosen membrane. If you need additional belts and braces for airtightness, your primary airtightness measures need to be looked at.
