ab12 Posted 18 hours ago Posted 18 hours ago I'm in the process of doing a full re-roof to replace old bitumen leaky felt. Would like to go with breather membrane that is air and vapour permeable. Any recommendations please. Pitched roof will be finished of with fibre cement tiles with a dry ridge system and eaves ventilation. It appears most of the membranes on the market are air tight and vapour permeable and a limited supply are both air and vapour permeable.
JOE187 Posted 18 hours ago Posted 18 hours ago https://klober.co.uk/membranes/roof-membranes/p/air-160 Tape all joints. 1
G and J Posted 17 hours ago Posted 17 hours ago We used this Permavent APEX is a 3 layer breather membrane. APEX is both air and vapour permeable 1
ab12 Posted 10 hours ago Author Posted 10 hours ago 5 hours ago, G and J said: We used this Permavent APEX is a 3 layer breather membrane. APEX is both air and vapour permeable Thank you everyone. Had a look at the prices and SD values Permavent £160 SD value 0.01 Roofshield £150 SD Value 0.013 and Klober £259 SD value 0.009 On paper Kolbre wins in terms of breathability but is there a bif difference between 0.009 and 0.1 SD value? If not then i think either Permavent or Roofshield Also I dont quite understand do thes emembranes to be taped or can they be used untaped. Look at the brochure if taped for example Permavent require 100mm overlap and if untaped then 150 mm overlap. In terms of tape- any specific type of tape ? or standard waterproof duck tape?
ab12 Posted 10 hours ago Author Posted 10 hours ago 7 hours ago, JOE187 said: https://klober.co.uk/membranes/roof-membranes/p/air-160 Tape all joints. Which type of tape please?
G and J Posted 5 hours ago Posted 5 hours ago 4 hours ago, ab12 said: Also I dont quite understand do thes emembranes to be taped or can they be used untaped. We did not tape but used the 150mm overlap (permavent)
JohnMo Posted 5 hours ago Posted 5 hours ago 7 minutes ago, G and J said: We did not tape but used the 150mm overlap (permavent) Neither did we
