ab12 Posted 2 hours ago Posted 2 hours ago Having UFH for 3 rooms: a kitchen , a bathroom and a living room. In the bathroom I will be having a walk in shower in the shape of a rectangular box dimensions 165cm long and 90 cm wide but without a shower tray. Worried shower trays break easily and also I think it will more cost effective to create the falls needed in the shower area with dry screed. On one of the longer sides will be a fixed glass screen running from external wall with a gap to walk into the shower space and on the opposite side is the internal wall. Shower head and taps will be affixed to external wall on one of the shorter sides of the rectangular box- see diagram attached I will make a small rectangular partition in the floor where the shower space will be if I use wet screed so can get the falls for the drainage. Floors will be finished with tiles. I am in 2 minds about Dry vs Wet screed. Dry Screed will be cheaper but a bit more laborious which I don't mind. Wet will off course be a quicker install but cost premium attached. For Dry I will go with 75mm thickness and for Wet I think the recommended is 60 -65mm thickness. Considering it's a DIY project which screed finish would you opt for? Are both types of screed equally effective for UFH in terms getting the space warmed up quickly and avoiding cold spots?. I suppose the thicker the screed the more time the slab will take to warm up but equally I suppose the more time that heat will be stored in the slab. BTW I have no prior experience with living with UFH so not sure about which direction to proceed.
JohnMo Posted 2 hours ago Posted 2 hours ago (edited) 57 minutes ago, ab12 said: Are both types of screed equally effective for UFH in terms getting the space warmed up quickly and avoiding cold spots?. Both will be equally slow, which is the whole idea of UFH. Unlikely to be any cold spots - but a floor well put together isn't hot either. Many because most if not all the time it's actually cooler than your body so will never feel hot. I assume you have thought about and installed plenty of insulation under the UFH pipes? Edited 1 hour ago by JohnMo 1
ab12 Posted 1 hour ago Author Posted 1 hour ago 14 minutes ago, JohnMo said: Both will be equally slow, which is the whole idea of UFH. Unlikely to be any cold spots - but a floor well out together isn't hot either. Many because most if not all the time it's actually cooler than your body so will never feel hot. I assume you have thought about and installed plenty of insulation under the UFH pipes? In terms of insulation I will putting 150mm PIR even though 100mm will suffice. Going with the extra insulation hopefully should be better. Initially though plan was to fit 100mm and so I purchased most of the boards already. Now have changed mind and will be ordering the 50mm boards. So I will be laying 50mm PIR first and them 100mm on top. In hindsight I should have ordered 150mm board. Other option is to use use 50mm Polystyrene such as Jabalit and then 100mm PIR on top- Cheaper option. Watched a you tube video about this and learnt the following: Polystyrene boards break easily and can be a bit more tricky to cut but I don't have prior experience so basing everything on what I saw in the video. Have you worked with Jabalite? Is it fairly easy to work with?
JohnMo Posted 1 hour ago Posted 1 hour ago 14 minutes ago, ab12 said: I will be laying 50mm PIR first and them 100mm on top. In hindsight I should have ordered 150mm board. Good - go with 150mm. But stuck with 100 and 50mm. 150mm are a pain to install well. Stick with PIR at that depth. You 50% more depth of polystyrene boards for the same U value as PIR. A blunt saw is good for cutting PIR. Foam in any gaps. Stagger joints between layers 1
Nickfromwales Posted 1 hour ago Posted 1 hour ago 1 hour ago, ab12 said: Worried shower trays break easily and also I think it will more cost effective to create the falls needed in the shower area with dry screed. It requires a methodical approach, and a lot of careful execution. Shower trays don’t typically break easily, more like mechanical damage or accidental dropping of things onto them. If you’re not having a shower tray then maybe consider a wet room former? You just set this in place with tile adhesive, test the drain for leaks, then screed to it. 1
