Mr Blobby Posted 3 hours ago Posted 3 hours ago Should biocide and corrosion inhibitor be added to the water in the UFH pipes? Any reason not to? If so then what product?
JohnMo Posted 2 hours ago Posted 2 hours ago Biocide, if a low temperature system add biocide, if used for cooling add biocide. Use same make as the inhibitor so biocide and inhibit from same ame manufacturer), so there are no compatibility issues. I used, Adey MC10+ Rapide Underfloor & Central Heating System Biocide, plus Adey MC1+ Central Heating Inhibitor. 1
