Ie, me! 😁
Hey folks, please forgive my naivity, but a couple of quick Q's around HETAS certification, if you would indulge me, please
1) In terms of obtaining a certificate for an existing wood stove/flue/hearth system - can any authorised fireplace installer inspect & grant certification?
2) if not a fireplace installer, then is there a recognised trader/entity who can undertake this?
3) if so, does anyone have a ballpark figure for inspection/approval? (Afaik, the certificate itself is approx £36)
This is purely from a research perspective, for potentially renovating an old stove in an outbuilding (which is exempt from building regs)
Many thanks for your time 😁
Shadow
Cheers for the input guys :D
Apologies, but had a busy few days, so unable to respond until now....
In response to the above:
1) Alas, i don't think there is an existing HETAS certificate - the previous owner did a self-install (single flue pipe through breeze block wall). Although the outbuilding strictly doesn't need it (as it's not subject to B Regs,), i wanted to obtain one, from an insurance point of view (if the unthinkable happened, and i needed to claim)
2) Agreed, i was planning on using a HETAS certified company/person to undertake this. However, to save on cost i wanted to build up the fireplace & let them just sort the stove/flue. As part of this, i was hoping they could certify the fireplace during the install.
If i did the install myself then i'd need BC to sign it off (i guess)< as i can't find any companies that specialise in inspection/approval 🤷‍♂️
That’s ok but they should have supplied you with a copy of the BC cert. I went that route by allowing a BC inspection and also detailing how I met the regs and manufacturer’s requirements. About a 6-page doc with drawings, photos during installation, test results etc.
Getting anybody to certify after the fact will be hard - nobody wants the liability of someone else’s potentially dodgy work.
If you bought recently your solicitor should have been on top of this.
Can you get an indemnity policy to cover WBS?
My house purchased was held up because there was no FENSA certificate.  Total waste of 100 quid.
Better still, rip it out.
