MikeGrahamT21 Posted 20 hours ago Posted 20 hours ago Happy Bank Holiday Monday everyone! so was just walking through the smaller bedroom which I’m in and out of regularly during the week as I work from home in there, and noticed a dreaded stain on the ceiling along a plasterboard joint 😭🙈 went up in the loft to have a look, of course this is right under the eaves, where else!? Now I think from memory of a time in my dads loft, this is the work of bees? something has nibbled a couple of holes in the roof membrane which I will patch up, the insulation did have moisture on it under the holes and you can see the timber and insulation that I’ve removed is very wet, but it’s sticky and matted. Also found some grey coloured nests, only small, maybe 5cm diameter, and a few what look like outer casings whatever the young grow in. can get a photo of those other bits if needs be, just having a breather for 5 mins of course I will leave this all open now until it’s fully dried out before putting anything back, but the membrane is going to get some airtight tape on it, just sprayed some tescon sprimer to give maximum adhesion. any insight greatly received! thanks!
elite Posted 15 hours ago Posted 15 hours ago Hard to tell from the pics, but I would say bumblebees - certainly doesn't look like honey bees Bumbles will only use a nest for one season, so this was probably last year and they shouldn't return Pic 2 of the second post, looks a bit like the base for a destroyed wasps nest
MikeGrahamT21 Posted 3 hours ago Author Posted 3 hours ago I wonder if both have had a go then, that grey papery stuff was a complete, like giant acorn shaped thing, but it fell apart when i moved it. All from the same area. Thanks for the reply. I'll let it all dry out and ensure no more leaks before i put everything back in place insulation wise. 1
