Super_Paulie Posted April 29 Posted April 29 my bathroom ceiling (first floor) is a mess, looks like its been a separate toilet and bathroom at one point and then converted into a toilet, bathroom and corridor. Now its all 1 room the ceilings are all over the place so ive lowered it down with C16 to get me a level surface. Its got a loft above with fibreglass insulation between, plastering lath is still here, and its going to stay there as well as its manky above it. My question is, should i fill this newly created dropped-ceiling void with tight fitting PIR and tape the timbers for my vapor control? The C16 is 38mm but packed out in places, often adding 25mm here and there to compensate the old ceiling, its that wonky. I could get PIR in there but it will leave dips and voids above it in places, any thoughts on mixed materials as i could pack it with 25mm fibreglass and then 25mm PIR level with the new, lowered ceiling timbers. Ceiling has a vent with an inline fan in the loft existing through the roof, room is small, 2.5m sq.
Nickfromwales Posted April 29 Posted April 29 Rockwool fill, 40mm PIR, foil tape, then PB. You’ll need to manage the holes for lighting, or use a surface mount / pendant. 1
Super_Paulie Posted April 29 Author Posted April 29 Annoyingly you can't get 40mm from the sheds, and delivery is mental costly from insulation specialists, especially for like 2 sheets only. I have some 50mm but don't think cutting that sideways would be very easy...
Nickfromwales Posted April 30 Posted April 30 15 hours ago, Super_Paulie said: Annoyingly you can't get 40mm from the sheds, and delivery is mental costly from insulation specialists, especially for like 2 sheets only. I have some 50mm but don't think cutting that sideways would be very easy... Work out the sizes you need, go to a merchant, and cut up an 8x4 in their yard.
Super_Paulie Posted May 1 Author Posted May 1 On 30/04/2026 at 13:58, Nickfromwales said: Work out the sizes you need, go to a merchant, and cut up an 8x4 in their yard. i'll see what we have around here, not sure i can fit any in my 2 seater though no matter how small i cut it... I assume the secondary foil layer on the back is as vital as the one on the front, so hacking 10mm off the 50mm i have is a no-go? I have like 4 full boards left over from all my build stuff that im just stuck with, would be useful to use it up here.
Nickfromwales Posted May 1 Posted May 1 5 hours ago, Super_Paulie said: i'll see what we have around here, not sure i can fit any in my 2 seater though no matter how small i cut it... I assume the secondary foil layer on the back is as vital as the one on the front, so hacking 10mm off the 50mm i have is a no-go? I have like 4 full boards left over from all my build stuff that im just stuck with, would be useful to use it up here. Cant you get the 50mm in there? Recess it where necessary etc.
Super_Paulie Posted May 1 Author Posted May 1 1 hour ago, Nickfromwales said: Cant you get the 50mm in there? Recess it where necessary etc. id have to take the plaster and lath off in places. I took it all off in the vaulted section and quite frankly im never doing that again in my life. Ive tested cutting the 50mm between 2 lengths of timber and i can reduce the depth, but the question is should i, as id be losing the foil on the "inner" side.
Nickfromwales Posted May 1 Posted May 1 2 hours ago, Super_Paulie said: id have to take the plaster and lath off in places. I took it all off in the vaulted section and quite frankly im never doing that again in my life. Ive tested cutting the 50mm between 2 lengths of timber and i can reduce the depth, but the question is should i, as id be losing the foil on the "inner" side. I can't see any reason it would be a problem on the back, but the front is usually taped (with foil tape) across boards and timbers to create the vapour barrier; this negates installing a dedicated VB. Working in a lath and plaster filled house currently (for my sins methinks) and I wholeheartedly agree.
Super_Paulie Posted May 1 Author Posted May 1 12 minutes ago, Nickfromwales said: I can't see any reason it would be a problem on the back, but the front is usually taped (with foil tape) across boards and timbers to create the vapour barrier; this negates installing a dedicated VB. Working in a lath and plaster filled house currently (for my sins methinks) and I wholeheartedly agree. The amount of debris you can generate per sqM is insane. I did the vaulted side to gain back the space as it was curved top and bottom and like 80mm thick and filled with rusted mesh. Whole thing was brutal, won't be doing that again. 1
Super_Paulie Posted Sunday at 22:43 Author Posted Sunday at 22:43 Just to put this to bed, job done. Just need to foam it in and tape it up, which I can't do until we have chosen our light position. Cutting a board down it's depth is horrible, but it meant I got rid of the remaining 50mm stuff I've had hanging around for years. Cheers Nick, onto the next thing. 1
torre Posted Tuesday at 07:34 Posted Tuesday at 07:34 On 03/05/2026 at 23:43, Super_Paulie said: Cutting a board down it's depth is horrible Endless amounts of dust 😞 Now you've done the hard part, I wouldn't leave it too long before foam, tape and boarding over - you'll be surprised how quickly the insulation will bow now the foil has been removed from one side. (Too late for you, sorry, but I'd probably have packed out the timbers with say 12mm ply strips and used longer plasterboard screws to avoid having to cut back the board depth)
Super_Paulie Posted Tuesday at 11:28 Author Posted Tuesday at 11:28 3 hours ago, torre said: Endless amounts of dust 😞 Now you've done the hard part, I wouldn't leave it too long before foam, tape and boarding over - you'll be surprised how quickly the insulation will bow now the foil has been removed from one side. (Too late for you, sorry, but I'd probably have packed out the timbers with say 12mm ply strips and used longer plasterboard screws to avoid having to cut back the board depth) its a fair comment. But as i was lowering the ceiling already i didnt want to lower it further. In the scheme of things, 12mm probably would have made sod all difference, youre right.
