16 hours ago, Post and beam said:
   A future owner of my house might want a pool, should i install one now
just in case. FFS!    Solar panels are very popular, green and likely to become mandatory soon. Should i also install some
Calm down dear 🙂
Solar panels are already Mandated by the Future Homes Standard - PV panels are now cheaper than roof tiles so it isa win-win for the builder as well.
Would a swimming pool help reduce the load on the national grid, or provide a habitat for wildlife?  Of course not.  Another strawman argument.
All of the rules that go into building regulations are assessed against safety and societel needs.  And apply to NEW BUILD not retrospectively unless a particular modification of your existing building brings it within scope (as with insulation or electrical upgrades)
Having said that, anyone who can afford to install solar panels but chooses not to (somehow paying for a new kitchen is more popular!) are only spiting themselves.
6 minutes ago, Oz07 said:
Maybe. When was the last time they fired up the boiler on the way round though
The BCO might not, but the assessor for any new owners mortgage should.
At the very least their solicitors will ask for paperwork during searches to confirm that the EV charger (or boiler or solar) has an installation certificate and up to date servicing record.
Just as a question. Not trying to strawman or whatever. If I built a house to basic b regs u values, would I be obliged to fit a heating system? Or for that matter even a water heating system?!
what servicing needs to be done on an EV charging point?
Have a look at Requirement G3 - they've even got you needing to provide hot water despite always washing in cold!
G3. (1) There must be a suitable installation for the provision of heated wholesome water or heated softened wholesome water to: (a) any washbasin or bidet provided in or adjacent to a room containing a sanitary convenience; (b) any washbasin, bidet, fixed bath and shower in a bathroom; and (c) any sink provided in any area where food is prepared.
Whatever next!
As set by the manufacturer.  For our chargers at work this is every 6 months, domestic will probably be 12 monthly until the warranty expires.
As with PV, (which should be checked at least once bi-annualy from my experience) the checks will mostly cover any screw connectors to ensure the neutrals are not working lose and causing resistance/arcing.  You could do this yourself, (if competent) but it probably voids the warranty if the inspection schedule is not maintained.
Newer installs have hopefully moved over to pushfit or Wago type connectons rather than screws (so there should be less issues), but, given the value of the item you are plugging into it, paying for a sparky to check the install once a year would seem like money well spent.
Not if you build a certified Passiv house and can prove that the indoor temperatures will meet regulation requirements.  In practice, most Passiv builders fit a (very) small heating system 'just in case'.
In the same way, we should fit EV chargers to new build - just in case the next owner (or even the current one) gets an EV.
Your personal preference may be to wash in cold water, but a house built to building regulations isn't built specifically for your personal hygene arrangements 🙂
We keep coming back to this without resolving why.  What is this 'should' nonsense?   Because the 'rules say so' is not what i mean by an answer.
The 'rule' is an unfair and ridiculous burden on the house builder.
I don't wash in cold water and do like a warm house i was just wondering how far these rules go. Do we all have to fit stairlifts soon? We do have an ageing population.
Ah, they have that covered too. If your planning permission switches on additional requirements in Part M - access for the disabled M4(3) requires space for a lift to be installed and/or dedicated sockets for a potential stair lift.
Originally the building regulations set a basic standard for health and safety of persons within and around the building. Most people could see the sense in requiring properly built buildings that were structurally safe, weathertight with decent drainage. Then conserving energy was added, then electrical safety, and then it all went to pot when internet connectivity, electric car charging etc were added.  By then the original purpose of the regulations had been subsumed into using them to carry out policy decisions of the government of the day.
Meanwhile, back in the real world…
Perhaps this happens with a very small amount of equipment fitted on the premises of big corporations, but I guarantee you it does not in the case of 99.99999% of domestics, even though it might be a good idea! It’ll get fixed when it breaks.
If the terminal has been correctly torqued, it pretty unlikely it will come loose.
I don’t fit loads of these, but I do fit 1 or 2 a month. Mostly Hypervolt and Andersen. I’m not aware of either of those requiring any servicing to maintain the warranty, or even suggesting it at all.
On 22/04/2026 at 15:00, sgt_woulds said:
Don't forget, if you have an EV charger fitted, you also need an SPD under current regulations.
To be honest SPD are so cheap these days I don't know why they are fitted as standard with a new installation anyway.
They are required regardless of EVC now as part of BS7671 in all new installations and boards - which is why almost all consumer units now come loaded with one.
