allthatpebbledash Posted 11 hours ago Posted 11 hours ago After reading quite a few previously asked questions, would I be allowed to assume the easiest and least faffing way of insulating a roof is to go above rafters all over? New pitched roof, covered in slate. Gable end to end, simple form. Probably hand cut timber rafters. Intergrated PV panels. Loft boarded for storage with hatch. New ceiling joists below. Was considering cold roof with mineral wool above new ceiling joists as cheaper but being advised it’ll open up potential to damp and mould. Told to go warm roof instead. Either between and below, between and above, or all above. The latter seems most simplest to not go wrong. Therefore, if I throw 140-150mm Recticel Eurothane or something above rafters, and as I have 2 ducts either end coming up from wet rooms on floor below for the dMEV units to extract via the roof, could I install an additional 2 units in the loft space on either side to tap into existing ductwork for any possible moisture to be extracted? Need to achieve 0.15W or better.
JohnMo Posted 11 hours ago Posted 11 hours ago Insulation above roof is in theory easy to do. But you need to detail well, think about how you seal the gaps between the roof insulation and join to the wall insulation. If you rafter is 150mm high you have a gap 150mm to fill at every rafter. 8 minutes ago, allthatpebbledash said: dMEV units to extract via the roof Why not through wall? Hybrid roof insulation 5 minutes ago, allthatpebbledash said: between and below, between and above, or all above Can be a recipe for disaster if you don't follow the rules and have a sound basis for construction.
allthatpebbledash Posted 4 hours ago Author Posted 4 hours ago 7 hours ago, JohnMo said: If you rafter is 150mm high you have a gap 150mm to fill at every rafter. Would that mean I’d be looking at a between and above solution then, like hybrid roof? Forgive my lack of understanding, I was under impression you could just plonk a ton of board on top of the rafters reducing the need to cut and fill? 7 hours ago, JohnMo said: Why not through wall? Aesthetic reasons, the soil stacks are also venting via same method so no visible pipes externally.
Mr Punter Posted 1 hour ago Posted 1 hour ago If you have external insulation you will need to work out how to fix battens / counterbattens. You will need a lot of very long fixings. I think the helical type work well. Expect to spend about £7/m2 in fixings for counterbattens.
allthatpebbledash Posted 49 minutes ago Author Posted 49 minutes ago 1 hour ago, Mr Punter said: If you have external insulation you will need to work out how to fix battens / counterbattens. You will need a lot of very long fixings. I think the helical type work well. Expect to spend about £7/m2 in fixings for counterbattens. Theres no EWI. Anticipating a concrete block cavity wall with cavity fully filled 100-150-100mm. So is it possible to avoid the filling between rafters and just place boards above them?
