March 23Mar 23 Hi Going to be putting electrics into my shed 50m from the house with some solar on the shed. Electrician has told me 25mm SWA 3 core but does it matter about the cable colours brown / blue/YG or brown black grey thanks
March 23Mar 23 No. The electrician will sheath the cables as required with the appropriate colours when he connects it all up.
March 23Mar 23 4 hours ago, GrantMcscott said: Hi Going to be putting electrics into my shed 50m from the house with some solar on the shed. Electrician has told me 25mm SWA 3 core but does it matter about the cable colours brown / blue/YG or brown black grey thanks That’s going to be expensive. What are you running down there to need that fat a cable?
March 23Mar 23 I've just spec'd a 16mm for 38m run off a 50a breaker at 32a assumed load (with cable direct buried). Circa 5v drop iirc. 25mm is big, but depends on what you're running, and for the above I left headroom over an EV charger to supply power and lighting to a man-shed.
March 24Mar 24 Author Hi Yes there will be general lighting, power needs, EV charger and 10KW Hybrid invertor with battery storage and future proofed
March 24Mar 24 3 hours ago, GrantMcscott said: Hi Yes there will be general lighting, power needs, EV charger and 10KW Hybrid invertor with battery storage and future proofed 25mm it is!
