Steve1309 Posted 1 hour ago Posted 1 hour ago We have a 3 bed end of terrace with no gas supply. The land next to the end wall is not ours. The front of the property opens straight onto a public path with about a metre gap. The back of the house has patio doors and a conservatory with no spare wall space. Short of knocking down the conservatory, does this rule out an ASHP? We're keen to ditch our old eco 7 storage radiators. TIA
DamonHD Posted 1 hour ago Posted 1 hour ago Is there no rear space beyond the conservatory? Do you have a flat roof, eg on a porch, that might host the external unit? https://www.installeronline.co.uk/green-energy/installing-ashps-on-roofs-and-walls-what-installers-need-to-know/ There are variants without external units, eg: https://www.etherma.com/en/blog/heat-pump-without-outdoor-unit
Steve1309 Posted 1 hour ago Author Posted 1 hour ago 21 minutes ago, JohnMo said: What outdoor space do you have, garden etc? Flat roof? Yes, there's a garden and the roof is a standard gable, thanks
Steve1309 Posted 1 hour ago Author Posted 1 hour ago 22 minutes ago, DamonHD said: Is there no rear space beyond the conservatory? Do you have a flat roof, eg on a porch, that might host the external unit? https://www.installeronline.co.uk/green-energy/installing-ashps-on-roofs-and-walls-what-installers-need-to-know/ There are variants without external units, eg: https://www.etherma.com/en/blog/heat-pump-without-outdoor-unit Yes, there's a patio and lawn and yes, there's a porch at the front (didn't think of that), Thanks
Conor Posted 24 minutes ago Posted 24 minutes ago You can stick it anywhere in the garden that won't be causing an inconvenience. Just need to size pipes and pumps appropriately. 1
Steve1309 Posted 10 minutes ago Author Posted 10 minutes ago 14 minutes ago, Conor said: You can stick it anywhere in the garden that won't be causing an inconvenience. Just need to size pipes and pumps appropriately. Ok, thanks
