crispy_wafer Posted February 23 Posted February 23 I'm in need of a tile cutter and looking for recommendations please. It's going to used for various porcelain wall tiles, probably with a depth no greater than 12mm. Mostly 600mm*300mm. We're not planning any tiles with diagonal face cuts. This is going to be a tool I'm going to use over the next few months then sell, so something that would be sought after secondhand would be good. Rubi, Sigma? So many models it's confusing?
Nickfromwales Posted February 23 Posted February 23 I own both Rubi (dry and wet) and Sigma (dry). The Sigma is hands down the best cutter I've ever owned. It's also an industry go-to, so you should be able to sell it on without too much of a loss. This will do you nicely, I have the larger one. LINK 1
Nestor Posted February 23 Posted February 23 +1 for Sigma. I purchased this https://www.protilertools.co.uk/product/montolit-63p5xl-masterpiuma-p5-power-5-manual-tile-cutter-63cm 1
crispy_wafer Posted Wednesday at 08:59 Author Posted Wednesday at 08:59 Thanks @Nickfromwales @Nestor, ordered myself a Sigma, and treated myself to a cordless angle grinder, a diamond cutting disc, and some edge polishing pads! These should see me right whilst I sort out the bathrooms. 1
Nestor Posted Wednesday at 09:04 Posted Wednesday at 09:04 I made some concrete worktops and used https://www.atsdiamondtools.co.uk for polishing pads. Have fun. 1
Nickfromwales Posted Wednesday at 10:46 Posted Wednesday at 10:46 1 hour ago, crispy_wafer said: Thanks @Nickfromwales @Nestor, ordered myself a Sigma, and treated myself to a cordless angle grinder, a diamond cutting disc, and some edge polishing pads! These should see me right whilst I sort out the bathrooms. You will need very good nerves to do all the flag cuts by hand. I'd say get a cheap wet bed cutter for these. Much quicker than sanding down every grinder cut, and waaaaaaaay less dust and mess. If using porcelain, you'll soon be reaching for the cyanide pill if you try to finish these all by hand. 1
-rick- Posted Wednesday at 10:52 Posted Wednesday at 10:52 4 minutes ago, Nickfromwales said: You will need very good nerves to do all the flag cuts by hand. I'd say get a cheap wet bed cutter for these. Much quicker than sanding down every grinder cut, and waaaaaaaay less dust and mess. If using porcelain, you'll soon be reaching for the cyanide pill if you try to finish these all by hand. The pro tilers on youtube make it look so easy. Then you watch an amateur try and do the same thing and it gives you pause. 1
Nickfromwales Posted Wednesday at 11:21 Posted Wednesday at 11:21 28 minutes ago, -rick- said: The pro tilers on youtube make it look so easy They also get to edit the videos..... 2
crispy_wafer Posted Wednesday at 11:31 Author Posted Wednesday at 11:31 To be fair, I did a cut with my old angle grinder last night to go from underneath and round the corner edge of the bathtub, took a bit of doing but turned out good I think. I’ve got an old cheap wet disc cutter but that creates more chips than McCain’s, so reluctant to use it for anything other than wall corners where the cuts will be out of sight.
Nickfromwales Posted Wednesday at 11:50 Posted Wednesday at 11:50 18 minutes ago, crispy_wafer said: To be fair, I did a cut with my old angle grinder last night to go from underneath and round the corner edge of the bathtub, took a bit of doing but turned out good I think. I’ve got an old cheap wet disc cutter but that creates more chips than McCain’s, so reluctant to use it for anything other than wall corners where the cuts will be out of sight. Less typing and more tiling I guess then! lol. 1
