WiltshireLink Posted 19 hours ago Posted 19 hours ago Hi All, Taking my stone slips up the side of my window reveals but I am wondering how I do the head? Going to use corner slips for the sides but unsure of the heads. What did you guys do? Thanks
JohnMo Posted 19 hours ago Posted 19 hours ago Where does your window sit, how far back, that may decide how you do it. My windows are flush with the wall so it was easy.
Russell griffiths Posted 18 hours ago Posted 18 hours ago Corner slips or mitre and glue your own. depends what look you want, do you want a large chunk of stone to look like a lintel stone.
Russell griffiths Posted 18 hours ago Posted 18 hours ago I did this, personal taste really, I would have like a big stone to look like a lintel, but was running out of enthusiasm and it just needed finishing.
WiltshireLink Posted 18 hours ago Author Posted 18 hours ago 53 minutes ago, JohnMo said: Where does your window sit, how far back, that may decide how you do it. My windows are flush with the wall so it was easy. Im in the Cotswolds so they are recessed about 80mm back inside the Nudura block
WiltshireLink Posted 18 hours ago Author Posted 18 hours ago 22 minutes ago, Russell griffiths said: I did this, personal taste really, I would have like a big stone to look like a lintel, but was running out of enthusiasm and it just needed finishing. So did you cut the top ones like a slip?
Russell griffiths Posted 18 hours ago Posted 18 hours ago 12 minutes ago, WiltshireLink said: So did you cut the top ones like a slip? All the stone was cut to 50mm thick and stuck on, then with the big ones I cut a notch out of the back and they sit on a chunk of 50x50 angle the underside will have a coloured ally trim to match the windows and hide the angle.
WiltshireLink Posted 18 hours ago Author Posted 18 hours ago Ah so a metal carrier then aluminium trim on the inside?
Russell griffiths Posted 5 hours ago Posted 5 hours ago 12 hours ago, WiltshireLink said: Ah so a metal carrier then aluminium trim on the inside? Yes, you could use pvc as well.
