WiltshireLink Posted February 15 Posted February 15 Hi All, Taking my stone slips up the side of my window reveals but I am wondering how I do the head? Going to use corner slips for the sides but unsure of the heads. What did you guys do? Thanks
JohnMo Posted February 15 Posted February 15 Where does your window sit, how far back, that may decide how you do it. My windows are flush with the wall so it was easy.
Russell griffiths Posted February 15 Posted February 15 Corner slips or mitre and glue your own. depends what look you want, do you want a large chunk of stone to look like a lintel stone.
Russell griffiths Posted February 15 Posted February 15 I did this, personal taste really, I would have like a big stone to look like a lintel, but was running out of enthusiasm and it just needed finishing.
WiltshireLink Posted February 15 Author Posted February 15 53 minutes ago, JohnMo said: Where does your window sit, how far back, that may decide how you do it. My windows are flush with the wall so it was easy. Im in the Cotswolds so they are recessed about 80mm back inside the Nudura block
WiltshireLink Posted February 15 Author Posted February 15 22 minutes ago, Russell griffiths said: I did this, personal taste really, I would have like a big stone to look like a lintel, but was running out of enthusiasm and it just needed finishing. So did you cut the top ones like a slip?
Russell griffiths Posted February 15 Posted February 15 12 minutes ago, WiltshireLink said: So did you cut the top ones like a slip? All the stone was cut to 50mm thick and stuck on, then with the big ones I cut a notch out of the back and they sit on a chunk of 50x50 angle the underside will have a coloured ally trim to match the windows and hide the angle.
WiltshireLink Posted February 15 Author Posted February 15 Ah so a metal carrier then aluminium trim on the inside?
Russell griffiths Posted February 16 Posted February 16 12 hours ago, WiltshireLink said: Ah so a metal carrier then aluminium trim on the inside? Yes, you could use pvc as well.
