Iceverge Posted Saturday at 12:55 Posted Saturday at 12:55 1 hour ago, saveasteading said: In a domestic situation I have no experience of barefoot winter use on an unheated tiled and well insulated floor. But the principle is simple enough. If the floor is 25°C or so from absorbing space heating then it won't suck heat from your feet, but that won't be an efficient process. That's the main issue I think. Ufh is inherently warm and gives you cosy feet then spreads to the air which can be cooler. Floor covering makes a lot of difference. Carpet and LVT throughout here. Efficient UFH with a floor at 25 deg won't feel much different on your toes from a well insulated slab at 20deg. Not chilly, not hot. UFH in a high flow temp situation is very nice on your feet but it's expensive to run. 1 hour ago, saveasteading said: I don't see any reason against having both, it's just heat transfer through pipes to the floor or to a fan. Cost and complexity?
saveasteading Posted Saturday at 13:13 Posted Saturday at 13:13 15 minutes ago, Iceverge said: expensive to run. I don't agree. 15 minutes ago, Iceverge said: Cost and complexity? Air to water I think we all know about. Some of that is taken to a plenum to heat air which is pumped into the room and a duct returns it from the other end. Simple but prob not for the typical installer who buys a kit.
