Simon Brooke Posted 16 hours ago Author Posted 16 hours ago Simple step would be to insert ball valves either side of the Wilo? I could be more radical and remove the Wilo altogether?
SimonD Posted 15 hours ago Posted 15 hours ago 30 minutes ago, Simon Brooke said: Simple step would be to insert ball valves either side of the Wilo? I could be more radical and remove the Wilo altogether? Better to plumb the flow and returns from the heat pump straight into the ufh manifold and remove the pump and tmv from the ufh, then run the heat pump at a realy nice low temp. I think this was the plan that was too much for the plumber you had in? Which is a worry..
John Carroll Posted 13 hours ago Posted 13 hours ago 1 hour ago, SimonD said: Better to plumb the flow and returns from the heat pump straight into the ufh manifold and remove the pump and tmv from the ufh, then run the heat pump at a realy nice low temp. I think this was the plan that was too much for the plumber you had in? Which is a worry.. 2 hours ago, SimonD said: Better to plumb the flow and returns from the heat pump straight into the ufh manifold and remove the pump and tmv from the ufh, then run the heat pump at a realy nice low temp. I think this was the plan that was too much for the plumber you had in? Which is a worry.. Agree, also, the Wilo Yonos Pico is the RR in pump control because it's head (and output) in CP mode can be incrementally changed in 0.1M steps to give almost infinite control, assuming of course that it can achieve the ASHP minimum requirement of 17.0LPM. @SimonD, where did you get this dP of 0.5M at 17LPM from and is 17LPM written in stone or can it be changed?, if it can, and could be reduced to say 14.5LPM to get the ASHP away, even as a temporary fix just now before any plumbing changes, then maybe worth looking at.
SimonD Posted 13 hours ago Posted 13 hours ago 11 minutes ago, John Carroll said: @SimonD, where did you get this dP of 0.5M at 17LPM from and is 17LPM written in stone or can it be changed?, if it can, and could be reduced to say 14.5LPM to get the ASHP away, even as a temporary fix just now before any plumbing changes, then maybe worth looking at. Here's the manual from Samsung - the serial number doesn't completely tie up, but it seems close enough altough Samsung's website suggests it's a split unit but the manual says mono. The unit and phe resistance curves are on page 25. I can't find a minimum flow rate as the specs just have a - in the tables for this. Not entirely helpful. But that's generally the feedback I've heard about Samsung and their heat pumps in the UK. EHS_MONO_ODU_IM_EN_DB68-05387A-07_181129.pdf 1
John Carroll Posted 11 hours ago Posted 11 hours ago (edited) Just wonder if there is a actual interlock via a flowswitch, etc, it just says the unit can stop, page 23, I think they can trip if the flow/return dT is too low, some alarm is surely flagged if the unit refuses to start. Could be something else stopping this unit from starting. There should really be a ABV between the flow&return anyway. Edited 11 hours ago by John Carroll
John Carroll Posted 11 hours ago Posted 11 hours ago Found this in the attachment but seems strange that this subject unit does not have its own pump?
