Dee Posted 10 hours ago Posted 10 hours ago Does that size sound right for 19 rads? I'm calculating the rad size for each room when the gadget arrives see if that's an issue too
Nickfromwales Posted 9 hours ago Posted 9 hours ago 11 minutes ago, Dee said: Does that size sound right for 19 rads? I'm calculating the rad size for each room when the gadget arrives see if that's an issue too A 12/14kw could suffice, depending on your heat load. 24kw is a lot, 30kw to space heating is huge. What gadget do you have coming? 1
JohnMo Posted 9 hours ago Posted 9 hours ago 46 minutes ago, Dee said: Does that size sound right for 19 rads? I'm calculating the rad size for each room when the gadget arrives see if that's an issue too Really depends on heat loss - start with the basics do a heat loss calculation. Then you will know what size you need. 19 radiators in a heat seize of a house and 19 radiators in a low heat loss house require different heat inputs. This will give you an easy means of getting somewhere close https://heatgeek.com/articles/heat-loss-calculations
marshian Posted 5 hours ago Posted 5 hours ago 3 hours ago, JohnMo said: Really depends on heat loss - start with the basics do a heat loss calculation. Then you will know what size you need. 19 radiators in a heat seize of a house and 19 radiators in a low heat loss house require different heat inputs. This will give you an easy means of getting somewhere close https://heatgeek.com/articles/heat-loss-calculations Exactly ^ WHS Do a decent heat loss calculation yourself or pay someone to do one. I had a 24kW boiler in a house with a 4 kWh heat loss at -2.5 Deg C OAT - it couldn't modulate down below 10 kWh so cycled like crazy in the shoulder seasons and wasn't that great for cycling in the middle of the winter either. When it was replaced I dropped down to a 16 kW boiler that could modulate down to 4.0 kWh - I could have gone down to 11 kW but I think HW recharge time would be longer than 30 mins which wouldn't be acceptable to me and also the smallest boiler 11 kW couldn't be range rated down. Make sure if you do oversize the boiler that you at least get one that has a decent turndown (modulation) that at least mitigates the oversizing issue.
