lookseehear Posted 3 hours ago Posted 3 hours ago I've had a couple of quotes for solar + battery + associated hardware and have three options on the table. We're looking at a 5kW array and probably a 10kWh battery. The options are SolarEdge or Libbi from one installer, or GivEnergy from another. The main difference that I can see is the first installer is offering a 3kW or 5kW inverter whereas the GivEnergy is 8kW. We have a small EV but we'll likely get a bigger one when all the work is done, so I'm leaning towards the GivEnergy. We're also expecting to put in a 10-12kW heat pump as part of our renovation and a >200l UVC. We're on Intelligent Octopus Go at the moment with a SyncEnergy 7kW charger, which I'd rather not replace but would do if it meant managing the whole system was easier. I'm not really sure how I'm meant to choose between these three options. Are there any obvious good or bad choices here? Ideally I'd like a system that can manage import/export, dump excess solar into EV/DHW and be as future proof as possible.
