BadgerBadger Posted 13 hours ago Posted 13 hours ago Hi hive mind! I need a sanity check please! Just installing our Ecodan heat pump which I got with big rubber block anti vibration feet. The heat pump bolts to the metal channels in the feet, but there's no obvious way to secure the feet to the ground/concrete slab. Is it right that it just sits there on the feet? I have solid/flat area so it should be stable, I was just slightly surprised.
JamesPa Posted 13 hours ago Posted 13 hours ago 1 minute ago, BadgerBadger said: Hi hive mind! I need a sanity check please! Just installing our Ecodan heat pump which I got with big rubber block anti vibration feet. The heat pump bolts to the metal channels in the feet, but there's no obvious way to secure the feet to the ground/concrete slab. Is it right that it just sits there on the feet? I have solid/flat area so it should be stable, I was just slightly surprised. Mine arent bolted down. Unit weighs 125kg so isnt going anywhere in a hurry!
JohnMo Posted 12 hours ago Posted 12 hours ago Mine just sat on the feet, but on gravel, we have 70+mph wind nothing moved.
Marvin Posted 11 hours ago Posted 11 hours ago 1 hour ago, BadgerBadger said: Hi hive mind! I need a sanity check please! Just installing our Ecodan heat pump which I got with big rubber block anti vibration feet. The heat pump bolts to the metal channels in the feet, but there's no obvious way to secure the feet to the ground/concrete slab. Is it right that it just sits there on the feet? I have solid/flat area so it should be stable, I was just slightly surprised. Our ASHP is on the flat roof completely exposed - over 100 mile an hour winds - 600mm long rubber feet - no movement so far after 4 years.
