scottishjohn Posted November 14 Posted November 14 now the winter has come with very high winds and driving rain --lots of it 50mph + i am experiencing some slight water penetration in some areas what is the best product to coat all theexterior walls with without making them shiny and changing the colour of the granite I suspect there are very small cracks in the pointing and maybe some of stone work certainly small as ther isn,t much you could repoint and as they used granite sand in the pointing its a real problem to chase them out
gaz_moose Posted November 14 Posted November 14 if you waterproof them and water does get in then how is that water going to get back out? I waterproofed some fence panels with some waterproofer from screwfix, the water just beads off it like a waxed car. some areas of concrete fence posts got sprayed in the same stuff and would repell the water. (i should really have a look to see how it is holding up when its next raining but not minging) I did read in the reviews that some mad man used it on a brick wall with good results.
Beau Posted November 14 Posted November 14 (edited) 14 minutes ago, gaz_moose said: if you waterproof them and water does get in then how is that water going to get back out? For those of us in very exposed locations when is the water going to get out? We get periods were you get several months were it rains most days and walls hang wet throughout. Our barn was like this and after a few weeks of wet weather the water would run down the inside of the wall. Ended up tanking the inside and lime pointing the outside which worked perfectly. John I have no magic answers sadly. On my workshop which has porous render and pointing I used some Thompsons water seal. It worked for 4 or 5 years but now needs doing again Old buildings can be a PITA Edited November 14 by Beau
Redbeard Posted November 14 Posted November 14 Safeguard Chemicals do 'Stormdry' (I think) and I once used (breathable) Belzona 5122. The hazard sheet had me dressed up like a deep-sea diver! I don't think it has been perfect but it made a significant difference to a house which received much oof its rain horizontally.
scottishjohn Posted Monday at 10:43 Author Posted Monday at 10:43 so far from my searching I can find a few different products that would work however because granite is non porous it will sit on top if i do it all voer and permagaurd say it it will discolour with age if it is not absorbed so best idea so far is to just paint it on all the pointing joints I can see now where new stone work has been done that even though waterproofer was added to the mix it changes colour when its wet so first trial will be to coat those areas and see if it then does not change when it gets wet then we on a winner my real problem is it was pointed --80-100years+ ago with a mix using granite sand + cament and ground cockle shells -- not lime mortar being a quarry with a stone crusher it is obvious why they used free granite sand and probably some of the beach as well it also looks similar colour to the stone work which is why all my repairs to insdie walls were sone in nornmal cement mortar no point in going lime which gould take weeks to dry I wanted to get on and as there was always going to be a gap to the TF inside any water could evaporate up the gap to the cold roof the small area i have repointed with modern cement mortar , were an absoute nightmare to chip out the rock hard old motar although the actual walls of course were built with lime mortar they even used the cockle shells in the infilll mortar and small stones in the center of the walls I have solid walls . not the usual outer skin then rubble and an innner skin its been mortared up all the way through that could acount for why the walls were basically so solid after best part of 250 years and why the trees growing around it when i came did not manage to move anything -that and the stone work is built on solid rock for most of it I dug down 3ft outside the walls before i started and it was built to 3 ft below ground level in most places I got more water ingress last year and i am guessing the walls which were open at top for 60 years were still drying out only showing above the downstairs window reaveals so some special attention will be paid to make sure its not coming around them IF i was doing it again i would fit lead around all the window openings ,full depth of wall but that would have meant pulling out all the lintels to do it but If anyone is doing similar and making window openings larger i would strongly advise that is the way to do it since istarted asking questions and looking around ifound that was the 100% cure for old stone walls especialy with lime mortar I have another water problem with my garage which was built from blocks attached to the unrenvated part of the building -- If I ever get round to doing that then this wall will not be showing .so iwill try the cheaper silicone cream on there which has a shiny finish TEMU special at £40 for 4 kgs as opposed to £150 for premagaurd --worth a try and disclouration will not be a problem there
