mjc55 Posted 11 hours ago Posted 11 hours ago We are building a Pod where we will live on site whilst building the house. We don’t want to finish the internal walls (plasterboard probably) of the Pod yet as this is a task for when we can move into the house and rearrange the Pod (to include a store room with external access) This is an Ecobrick build - we are mimicking the main house so that we can potentially sort out any issues before the main build, I was wondering what would be best for "painting" the parged walls to a) lighten them and b) reduce the roughness. Any suggestions welcome as what makes sense to use as a short term (no more than a year hopefully) solution.
JohnMo Posted 11 hours ago Posted 11 hours ago Our walls are Durisol (pre Ecobrix), we parge coated with a cement, lime, building sand. Mixed with water to a double cream consistency. Then applied with a broom. It fills all the holes in the block and all joints. Wall becomes airtight after. Should last for ever. If want any colour other than grey paint it after. 1
JohnMo Posted 11 hours ago Posted 11 hours ago Mix ratio is on here https://forum.buildhub.org.uk/topic/25228-airtightness-parge-coat-vs-airtight-paint/
mjc55 Posted 10 hours ago Author Posted 10 hours ago Thanks for that but we have already applied the parge coat. The question is about what to paint with as a temporary - but I would expect to be in the pod at least 9 months so want something other than the grey parge coat finish.
JohnMo Posted 10 hours ago Posted 10 hours ago Masonry paint or emulsion. Try on a small area, make sure it stays put before you commit.
